The Next 'Big' Thing in 3D Printing
Big Area Additive Manufacturing, or BAAM, is attracting entrepreneurs and machinery developers.
Thermwood's developmental BAAM system with American Kuhne extruder.
Additive manufacturing (AM), better known as 3D printing, is big news these days, and the news in AM is “Big,” as in Big-Area Additive Manufacturing, or BAAM. Visitors to June’s Amerimold exposition in Rosemont, Ill., got an impression of where BAAM is headed. Oak Ridge National Laboratories, Oak Ridge, Tenn., showed off examples of its BAAM work at its Manufacturing Demonstration Facility. ORNL made news this past January with its 3D printed Shelby Cobra sports car, which debuted at the North American Auto Show. At Amerimold, ORNL showed an example of its current thrust in making molds for automotive, aerospace, and other composites fabrication. It exhibited a honeycomb section of mold made from ABS with 20% chopped carbon fiber, deposited by an injection molding-type extruder mounted on a CNC gantry in a machine built by Cincinnati, Inc. Capable of dispensing up to 100 lb/hr, it was described as “FDM on steroids” by Dr. Chad Duty, ORNL group leader for deposition science & technology. FDM is fused deposition modeling, an AM method of depositing a hot, continuous filament of thermoplastic in layers to build up a part. In BAAM, the layers can be around 1/8-in. thick.
Duty estimated that a car hood mold could be built in a “couple of hours” and could then be finished with a conventional gel coat. It could then be used for room-temperature cure of epoxy/carbon fiber composites. He said ORNL is working on PPS, PSU, and PEEK tools capable of withstanding elevated-temperature autoclave molding. It has already tested PPS with 40% carbon fiber. At Amerimold, ORNL also showed off a 35-lb chair made in one piece in half an hour from ABS with 20% carbon fiber. It has been load tested to support up to 600 lb.
Besides the Cincinnati machine, ORNL has worked with a six-axis, articulated-arm robot with a material deposition head. Additional options may be available in the near future. For example, CNC router supplier Thermwood Corp., Dale, Ind., is developing a BAAM machine with a six-axis, gantry-mounted extruder from American Kuhne, Ashaway, R.I. The initial development machine, nearing completion, can make parts up to 10 x 10 ft x 5 ft high. The vertically mounted, 1.75-in. extruder can process over 100 lb/hr. After deposition, a second head on the same machine can machine the part to its final shape.
A second new effort along these lines is a collaborative effort by two firms in Ohio, that are coming at the technology from the extrusion side. Year-old Strangpresse LLC in Youngstown, an extruder builder, is working with Md Plastics of Columbiana, which is supplying special screw, barrel, and check-valve technology derived from injection molding. The goal is to build a vertical, robot-mounted extrusion head that can deposit around 100 lb/hr in a highly controlled fashion. Still in development, the system is designed to ensure highly precise and uniform volumetric deposition of melt as the head moves over a large area at high speed with sudden turns, starts, and stops. The check valve is intended to prevent drool and stringing when deposition stops. The two firms aim to collaborate with a robotics firm to develop a complete BAAM system using a six-axis robot. Expect to hear more on this project in the near future.
How Additive Manufacturing Can Help, not Hinder, Injection Moldability of New Designs
Four cost drivers—design for moldability, mold-base size, internal componentry, polish/custom finishing—dictate the financial and processing success of a molded part design. Learn how 3D printing can assist this process, while also understanding its potential pitfalls.
Read MoreMake Every Shot Count: Mold Simulation Maximizes Functional Parts From Printed Tooling
If a printed tool only has a finite number of shots in it, why waste any of them on process development?
Read More420 Stainless Steel Now Qualified With TrueShape 3D Printing Technology
NPE2024: Mantle's Additive Manufacturing Technology is Designed for Precision Tooling
Read MoreNew Tool Steel Qualified for Additive Manufactured Molds and Dies
Next Chapter Manufacturing says HTC-45 — an optimized H-13 — will offer superior thermal transfer and longer tool life.
