Air-Ring Upgrade Pumps Up the Output
Film processor Dallas Plastics boosts throughput by as much as 40% by retrofitting a new air ring—without the need for IBC.
Output increases equal to that of adding internal bubble cooling without the “expense and headaches” associated with IBC. That’s how Miguel Sanchez described his experience following the installation of a new air ring at Dallas Plastics Corp.’s blown-film plant in Wentzville, Mo.
Sanchez manages that plant, one of three facilities operated by Dallas Plastics, which was established in 1989. The company specializes in converter-grade films for printing, laminating, and automated packaging, and offers a wide range of specialty films such as narrow-width lay-flat tubing, critical-tolerance films, non-scratch LDPE, and high-tensile-draw tape for drawstring bags. Its films are used in a wide variety of markets that include food, medical, agricultural, retail, automotive, aircraft, and electronics.
In Missouri, Dallas Plastics runs 24:7 on 12 monolayer lines that range in size from 3/4.-in. to 12-in. die diam. Film thickness ranges from 3/4 mil to 7 mils. Company-wide, Dallas Plastics runs layflat widths to 60 in., though Sanchez’s plant focuses more on small-size tubing. Dallas Plastics runs a wide range of LDPEs and blends of LDPE/EVA or LLDPE/EVA, the latter based on both hexene and metallocene technologies.
Like most PE film processors, Dallas Plastics is regularly on the lookout for technologies to increase capacity. Last year, it considered retrofitting IBC on some lines, but ruled it out because of cost.
“It’s not just the IBC system itself, but you have to invest in a new die that can accommodate the IBC, along with new blowers and other components,” says Sanchez. Instead, acting on a tip it received from a fellow film processor, Sanchez opted for a patent-pending air ring offered by Addex Inc., USA, Newark, N.Y.
Addex introduced the Intensive Cooling Air Ring in 2016. It utilizes up to four stacked cooling elements with a surrounding enclosure, all topped by a conventional air ring. But Addex quickly realized that this technology was probably better suited for brand-new lines, so at K 2016 it showed a scaled-down version specifically targeting the retrofit business.
Dallas Plastics’ $30,000 investment in a new air ring paid for itself in five months.
In the Intensive Cooling Air Ring, the standard lower lip on Addex’s dual-lip air rings is replaced with a single intensive-cooling element. As Addex explains, this transforms the previous low-velocity lower lip into a high-velocity air stream, creating two primary locking points instead of just one, to significantly improve bubble stability. The Intensive Cooling air rings also include all the secondary air-collar locking points of the original air-ring design, says Addex. The units are reported to be simple and operator friendly, allowing a broad range of processes, blow-up ratios, thicknesses, and materials with minimal adjustments.
Dallas Plastics ordered two of the new air rings, one for the Missouri plant and the other for its facility in Longview, Tex. In Missouri, the new ring was installed last May on a 10-in. die. Installation was fast and easy—“like putting on your socks,” Sanchez notes—and the $30,000 investment started paying off immediately.
Addex guarantees a 10-15% output bump, but Sanchez reports output gains of 15-20% on average, and up to 40% in some cases, depending on the resin blend, with no negative impact on film properties.
“The investment has already paid for itself,” Sanchez said in late November, roughly five months after the air ring was installed. Sanchez adds that Dallas Plastics has on order a third Intensive Cooling Air Ring, which will be installed early this year on a 12-in. line at its headquarters facility in Mesquite, Tex.
New Blown-Film Cooling Technologies Set to Debut at NPE2024
Cooling specialist Addex to roll out new auto-profiling air ring for rotating dies, and new single-plenum air ring.
Read MoreBreaking the Barrier: An Emerging Force in 9-Layer Film Packaging
Hamilton Plastics taps into its 30-plus years of know-how in high-barrier films by bringing novel, custom-engineered, nine-layer structures resulting from the investment in two new lines.
Read MoreFilm Processor Automates Complex Resin Management, Blending & Distribution System
Polipak of Poland moves to BlendSave system to support sustainability and Industry 4.0 objectives.
Stackable Bubble-Cooling Rings Offer Huge Output Gains
Next-generation bubble-cooling system is said to boost throughputs by as much as 60% in blown film.
