Thermal Care Breaks Ground on New Building
Relocation to new facility is planned for March 2016.
Members of the Thermal Care management team recently attended the ground breaking ceremony for its new building located less than a mile from its current location in Niles, Ill. The new state of the art facility will have 135,000 ft2 with room for expansion, vs. the 85,000 ft2 of its current location. Thermal Care hopes to start relocation in March 2016.
Thermal Care engineers, designs and manufactures industrial process cooling systems, cooling towers, chillers, and temperature control units for use in industrial processes worldwide.
Cooling the Feed Throat and Screw: How Much Water Do You Need?
Cooling Geometry and the Reynolds Calculation
The original Turbulent Flow Rate Calculator worked well with a round circuit diameter, such as a drilled passage, but not as well using hydraulic diameters. Here’s how the problem was fixed.
