Advancements Discussed At Plating-On-Plastic Summit
MacDermid hosted a Plastic-On-Plastic Summit where the latest advancements in POP technology were discussed.
Earlier this month, specialty chemicals supplier MacDermid Industrial Solutions, Waterbury, Conn., hosted a two-day Plating-On-Plastic (POP) summit at the impressive Chrysler Museum in Auburn Hills, Mich. MacDermid specializes in surface finishing, pretreatments and is a leader in POP technology for the automotive, electronic, aerospace, plumbing and other industries.
The company updated attendees on the latest advancements in POP technology. Included is the company’s new Electrolac UV process. It allows for curing a colored lacquer by UV instead of at high temperatures so that the coatings can be used effectively on plastics. POP advances in double-shot molding, and a qualification process for decorative fashion finishes were also discussed. Of particular interest were presentations on molding and plastics by Mitch Gordon, OEM account manager at Synventive Molding Solutions, Livonia, Mich., and Brian Grosser, business director USA/Mexico of Samsung Chemical USA, Detroit, respectively. A round table discussion with officials from Chrysler, Ford and General Motors was another highlight on the topic.
The decorative or functional applications of plating metal on plastic substrates is accomplished with the electroplating process. Before electroplating, plastics need to be metalized which is achieved by etching the surface to provide a tough bond and then coating the roughened surface with traces of a precious metal. Nickel and chromium are the most commonly applied, normally called ‘chrome plating’ or ‘plastic chrome plating’. This coating provides both technical and aesthetic benefits and can be applied to meet the criteria of a broad range of applications.
For example, highly-visible and corrosion-resistant exterior automotive components are often chrome plated plastics, which provide a lower weight option to metal components. Plastic chrome plating has also been found to be ideal for sanitary fittings that require a durable and wear-resistant coating to resist the humid bathroom environment. Similarly, electronic devices often benefit from EMI-RFI shielding of sensitive electronic components for which plating on plastic can be ideal.
MacDermid also discussed its latest innovation in hex-chrome-free pretreatment. Called evolve the new process is an acid-based solution that allows for etching of plastics without chromium trioxide, permanganate, or PFOS (perfluorooctane sulfonate)--a substance that has been traditionally used as a mist suppressant in hexavalent chrome processes and which is being banned as it is considered a substance of high concern (SVHC). The evolve process requires no extra process tanks or processing times when compared to conventional metallization cycles. MacDermid revealed that it is currently in production, meeting automotive specifications and demonstrating outstanding adhesion.
PEEK for Monolayer E-Motor Magnet Wire Insulation
Solvay’s KetaSpire KT-857 PEEK extrusion compound eliminates adhesion and sustainability constraints of conventional PEEK or enamel insulation processes.
SPE Automotive Awards Applaud ‘Firsts’ and Emerging Technologies
The 51st annual SPE Automotive Innovation awards gave nods to several ‘firsts’ and added alternative vehicle systems category.
Molder Repairs Platen Holes with Threaded Inserts
Automotive molder ITW Deltar Fasteners found new life for the battered bolt holes on its machine platens with a solution that’s designed to last.
