Maguire Ultra
Building a Better Buffer: Conveyor Tech at the Core of Lights-Out Molding Cell
An automatic climbing wall inspired the conveying technology at the heart of a lights-out two-machine molding cell churning out fully inspected and assembled automotive oil-filter drains.
Family-owned Happ Kunststoffspritzgusswerk und Formenbau GmbH (Ruppichteroth, Germany), which began life in 1964 making lunch boxes and furniture fittings, has turned a 2014 project to create an automated climbing wall, where users can adjust the angle and speed of the “ascent”, into a side automation business. A business that occasionally supplies systems to Happ.
Happ established that subsidiary—ErgoTek—in 2015 after the 2014 creation of the Ergo-Wall. Today, the original Ergo-Wall is at the University of Potsdam helping train physiotherapists. Since 2018, Happ has used the modules at the heart of the modular conveyors to create industrial automation systems, including its FlexiTek system, which uses precise timing to create buffer inventories. These are particularly useful in lights-out injection molding operations that combine multiple components—often with disparate cycle times—into a final assembly.
EcoPower 110/350 injection molding machines
Two EcoPower 110/350 injection molding machines from are inked together by conveyor systems with buffer capacity.
Since 2018, the modules at the heart of the modular conveyors have been used in industrial environments. In 2019, the modular conveyors, primarily used for timed production systems, were supplemented by the FlexiTek system. FlexiTek systems provide buffering capacity and can be optimized for injection molding.
Happ Utilizes ErgoTek Tech
ErgoTek recently completed a full system to flexibly link two Wittmann Battenfeld EcoPower injection molding machines via conveying systems with buffer capacity. In this cell, the outer and inner tubes of automotive oil-filter drain screws are automatically assembled, inspected, laser-printed and deposited in a shipping container.
oil filter drain screw
Inside and outside tube of the oil filter drain screw at left and the finished product on the right.
In this system, two 125-ton EcoPower 110/350 machines are integrated, each of which equipped with a W818 robot from Wittmann. The Wittmann EcoPower’s mold the inner and outer tubes of the oil filter drain screw from 2-cavity molds. The parts are then removed by the robot, which presents them to a camera to inspect the parts’ dimensional accuracy. Another camera examines the parts for burrs. Next, the tubes are transported by FlexiTek conveyors from ErgoTek and buffered for cooling.
A Scara robot then assembles the outer tube onto the inner. With the help of an articulated robot and a further camera check, the depth is measured, and the parts are transferred to a labeling band for laser printing. From there, the finished components are transferred to the Flexi buffer from ErgoTek.
A Wittmann Battenfeld spokesperson told Plastics Technology the components are molded from a glass-fiber reinforced PA6, and they must cool for at least 4 minutes. The cycle times for the two parts are both approximately 19 seconds. “The control concept is designed in such a way that the conveyors communicate with the robots via signals,” the spokesperson said, “and that autonomous operation is maintained in the event of a fault.”
Flexi conveyor
Flexi conveyor testing appliance from ErgoTek featuring parts made by Happ.
The assembled parts are deposited into Euro containers or KLTs. Once 90 are inserted, the KLT is ready to deliver to the customer. Apart from swapping out new KLTs every 2-3 hours, the process runs lights out sans human intervention. Happ says this system has made cost-efficient manufacturing of this product possible. Apart from economy, other benefits include eliminating the storage of work-in-progress parts, which also allows cavity tracking and better lot-to-lot traceability. In addition, parts can be removed automatically at preset intervals for SPC processes, and if an interruption occurs with any part of the cell, the other components can continue their production for up to one hour.
In all, Happ has seven all-electric EcoPower machines from Wittmann Battenfeld. Most of the machines from the EcoPower series are equipped with Wittmann’s W818 and W822 robots and to dry its materials, the company uses a Wittmann central material drying system.
Ergo-Wall
Ergo-Wall—the first product from ErgoTek for recreation and physiotherapy.
HAIDLMAIR NPE2024
Uway LLC
Dover Clear
Plastics Recycling Latam
Maguire Ultra
Shuttle Mold System
Automation
An Automation 'First' for Non-Servo-Eject Trim Presses
Compact, flexible and configurable robotic system is said to be the first to enable thermoformers to fully automate product handling after a non-servo trim press.
Thermoforming
Cobot Creates 'Cell Manufacturing Dream' for Thermoformer
Kal Plastics deploys Universal Robot trimming cobot for a fraction of the cost and lead time of a CNC machine, cuts trimming time nearly in half and reduces late shipments to under 1% — all while improving employee safety and growth opportunities.
Sponsored
Five Ways to Increase Productivity for Injection Molders
How Was K 2022 for Blow Molding?
Over a dozen companies emphasized sustainability with use of foam and recycle, lightweighting and energy savings, along with new capabilities in controls, automation and quick changeovers.
LIM & LSR Molding
Machinery & Robot Developments at Wittmann Battenfeld
Open house celebrates expanded U.S. headquarters & showcases innovations.
Injection Molding
Wittmann Battenfeld USA Expands, Adds Injection Machinery Manager
Last month, Wittmann Battenfeld USA finalized plans for a $2.4-million, 20,000-ft2 expansion at its Torrington, Conn., headquarters.
Postindustrial
Wittmann’s 40th Anniversary Gala Unveils New Products
New machinery, robots, and auxiliaries demonstrate continued momentum of technical development—and preview some K 2016 exhibits.
Advantage chillers and temperature control units.
