chemical foaming agents endothermic and exothermic
A new kind of recycling facility is taking shape on the banks of the Ohio River. PureCycle’s Ironton, Ohio, site is nearing completion of a massive expansion that will create an industrial-scale facility for purifying post-consumer polypropylene.
Polypropylene is favored for many applications due to its high specific strength, resistance to heat and chemical degradation, and versatility. PP products can and are made in innumerable shapes and colors, formed from fibers, containers, films, and more. But this versatility becomes a challenge when recycling PP. Recycling of HDPE milk jugs, for example, is facilitated by the uniformity of the target. Material recovery facilities (MRFs) everywhere exploit the way HDPE natural containers reflect light, using optical scanning systems to sort them from mixed streams.
Grey black pellets
Gray pellets resulting from traditional recycling of mixed color PP. This material will be processed as feedstock by Purecycle.
Photo Credit: Matt Stonecash
With PP, recovery facilities are dealing with a much broader mix of formulations, colors, and morphologies. The result is a mixed-color flake that becomes a gray pellet. The gray pellets have value and can become new products, but that value is limited by the available applications. You cannot take those mixed flakes and turn them back into clear pellets that look like virgin material. Or can you?
Hands holding clear pellets.
Purecycle’s product: clear, pure PP ready for conversion.
New Solution to the PP Recycling Problem
Aiming for higher quality than is produced by mechanical recycling, and lower environmental footprint than from existing chemical recycling processes, consumer-goods giant Procter & Gamble developed and patented a solvent-wash recycling process for PP. In 2015, PureCycle Technologies was created to scale up the technology and was licensed to commercialize the process.
The new plant is on the site of a former Dow facility that produced polystyrene. Lawrence County Development Corp. had purchased the property, hoping to find a use that would help the area recover employment and economic activity. They found PureCycle, and in 2019 the pilot plant began processing carpet into recycled PP.
“It’s a good area,” says Dustin Olson, CEO at PureCycle. “You want to be close to people and close to industry, because that’s where you get post-consumer and post-industrial waste. “
Construction is nearing completion of the scaled-up, modified version of the pilot plant at the same site. It is expected to be finished in April, and will have a capacity of around 100 million lb/yr.
Cleaning Plastic at the Molecular Level
Diverted waste material will start in the prep facility, where PureCycle has a variety of familiar equipment for preparing the various manifestations of PP products. There are agglomerators for densifying film and fibers, a grinder for breaking down rigids, and a washing line for removing external contaminants.
Prepped materials feed into one of a pair of KraussMaffei extruders that in turn deliver melted plastic to the heart of the plant, the solvent purification system. Over 100 ft high, the purification system is crisscrossed with a complex network of piping. But each component has its purpose.
“Think of it as a molecular washing machine,” says Olson. “At a mechanical recycling facility, they wash the outside of the plastic. I will wash through it.”
Polypropylene processing plant
PureCycle’s purification system for PP. Modules were fabricated in Texas and shipped upriver for assembly at Ironton, Ohio. (Photo: Matt Stonecash)
In the extraction column, melted PP is introduced to a solvent under critical conditions. Under these conditions, organic, non-PP materials such as processing additives are separated from the PP. A settling stage then removes inorganic materials; and finally the material is filtered, leaving pure polypropylene. The company refers to its PP pellets as a “no-compromise” drop-in replacement for virgin, fossil fuel-based PP. The solvent is reusable, so it is recovered and routed back through the process.
Process Efficiency and a Sustainability Edge
PureCycle has used its pilot plant to refine its process for efficiency. Lifecycle analysis indicates the solvent-based recycling process provides 35% smaller carbon footprint than virgin, fossil-based PP production. There is reason to think this number will likely increase in the future, as the process is far more energy efficient than virgin PP production, using 79% less energy per pound of product.
Ironton is part of the Huntington-Ashland metropolitan area, where Ohio meets Kentucky and West Virginia, and where energy comes mostly from coal. Reports from the Intergovernmental Panel on Climate Change (IPCC) have identified coal combustion as the energy supply with the largest lifecycle greenhouse gas emissions. Any change in energy mix will therefore allow PureCycle to reduce its carbon footprint even further. One strategy the company is exploring is rooftop installation of solar panels on some of the site’s buildings.
In Augusta, Ga., the planned location of Purecycle’s next facility, the energy mix is already very different, thanks to a nearby nuclear power plant. “We’ll have a much lighter carbon footprint there than we will here,” says Olson. Water usage is also expected to be reduced through the company’s investment in a more efficient water-treatment system from Krones.
Building a New Operation Amid Tumultuous Times
When construction on the new plant began, the COVID-19 pandemic had already hit. The global semiconductor shortage, the war in Ukraine, and the COVID surge that hit Germany last fall have all impacted the delivery of necessary equipment. Plans for opening in 2022 had to be delayed.
“The world is tough right now for the supply chain”, says Olson. “When we build in Augusta, it will be a much smoother process.”
Despite disruptions caused by war, a pandemic, and all the associated logistical problems, the site is now a flurry of activity as construction nears completion.
Bale of reclaimed yard signs.
Dustin Olson, CEO at PureCycle, with recovered yard signs promoting candidates of all stripes. The signs are of PP and will be turned into like-new pellets. (Photo: Matt Stonecash)
Recycled PP carpet, containers, film, even political campaign signs, are on-site and ready to be processed. Soon, renewed PP pellets will start rolling out of Ironton. PureCycle is confident that when they do, customers will be pleased with what they see.
“We’re the only ones in the world that can make a product like this. No matter what happens with prices in the short term, people are going to want it,” says Olson. “If they have a goal to reduce fossil PP usage, and they have a product that demands higher quality than mechanical recycling, they should be calling us.“
PureCycle plans to open the Augusta facility in the second half of 2024 with initial capacity of at least 260 million lb/yr. The company will expand its operations into Asia and Europe in the future with planned plants in Ulsan, South Korea, and Antwerp, Belgium.
Blending Revolution
AM Workshop
We Love Powders NPE
Dover Clear
Konica Minolta
Make Every Pellet Count
Shuttle Mold System
NPE2024: The Plastics Show
Dri-Air
HAIDLMAIR NPE2024
Revolution Develops Innovative Approach to Recycling Stretch Film
The company’s approach includes collection, cleaning and recycling of stretch film.
Postconsumer
Clothing Reseller Finds Recycling Pathway
A partnership between ThredUp and Azek will recycle clothing bags to composite deck products.
Postindustrial
Vecoplan Opens New Location in Southern California
The company’s new office will allow the company to more effectively service  customers in the country’s western region.
plant tour
Inside the Florida Recycler Gearing Up to Take on Scrap at NPE2024
Hundreds of tons of demonstration products will be created at NPE2024 next spring. Commercial Plastics Recycling strives to recycle all of it.
Recycling
Making Polypropylene the Next Big Thing in Recycling
PureCycle Technologies’ solvent-based recycling process returns polypropylene to a pristine state.
PureCycle to Supply Recycled PP to Berry
The material will be supplied to Berry in summer 2023 for manufacturing at one of Berry’s ISCC PLUS certified facilities.
Recycled Materials
Solvent-Based Recycling: Emerging Technology for Reclaiming & Purifying Polyolefins with Twin-Screw Extruders
Just now being applied commercially, solvent-based recycling turns colored polyolefin waste into clear, clean and even food-grade resin comparable to virgin—all while keeping the polymer structure intact. Specially engineered systems of tandem twin-screw or twin- and single-screw extruders can do the trick.
