Aitrtech
Calculating MDL & LOQ
Calculations:Standard Deviation:(see top right)  Ϭ  = The sample standard deviationN = The number of values in the data setxi  = An individual value of the data setx-bar = The mean of the values in the data setMethod Detection Limit (MDL):(see center right)t = “Student’s t value” for the number of replicates at the 99% confidence level. (Can be found in a reference table in a statistics textbook, or on the internet.
Calculations:
Standard Deviation:
(see first image right)
data set
(see second image right)
(Can be found in a reference table in a statistics textbook, or on the internet. The value changes with the confidence level and the number of replicates used. For this example the student’s t value equals 3.143).
Limit of Quantitation (LOQ):
(see third image right)
Using these calculations with the example data set:
Mean value = 21.94 mg
Standard deviation = 1.02 mg
MDL = 3.2 mg
LOQ = 10.2 mg
Since the instrument detects mass, the detection limits are in units of mass. This means that the percent moisture that can be detected is a function of the sample size. In other words the MDL for a 10-gram sample size would be 3.2 mg/10 g = 0.032%. For a 50-g sample size, the MDL would be 3.2 mg/50 g = 0.0064%. The larger the sample size, the lower the percent moisture you will be able to detect.
Repair and Rectify
3D printing machine trainings
