WSB Gravimetric Blenders
Chemtura Sheds EPDM
Chemtura Corp., Middlebury, Conn., one of the world’s three largest EPDM producers, will sell its EPDM business and some of its rubber chemicals to Lion Chemical Capital, LLC of New York and Houston.
Chemtura Corp., Middlebury, Conn., one of the world’s three largest EPDM producers, will sell its EPDM business and some of its rubber chemicals to Lion Chemical Capital, LLC of New York and Houston. Lion also owns stakes in Lion Copolymer, Baton Rouge (SBR); Excel Polymers, Solon, Ohio (elastomers and additives); and Sonneborn, Mahwah, N.J. (white oils).
  • How to Configure Your Twin-Screw Extruder: Part 3
  • The Path to Pellet Perfection
    In underwater pelletizing, numerous variables in the equipment, process and material affect pellet shape, consistency and quality factors such as fines. Defining the “perfect” pellet depends on the conditions of end use, and achieving that ideal requires understanding  of the causes of imperfections.
  • How to Configure Your Twin-Screw Barrel Layout
    In twin-screw compounding, most engineers recognize the benefits of being able to configure screw elements. Here’s what you need to know about sequencing barrel sections.
Masters of Blending
