Micromolding with COC
A pretty impressive example of micro injection molding is this “microwell array,” which has millions of tiny wells measuring 3 microns in diam. and 3 microns deep, with a pitch of 6.5 microns.
with a pitch of 6.5 microns. These features appear on a standard microscope slide and are used in genomics, life-science, and biomedical assays that utilize microspheres or beads. Until now, the industry relied primarily on etched silicon or glass microwells. The part is molded by microPEP, div. of Precision Engineered Products, LLC in Attleboro, Mass. It selected Topas cyclic olefin copolymer (COC) from Topas Advanced Polymers, Inc., Florence, Ky., based on its excellent flow and surface replication, as well as high purity, biocompatibility, chemical resistance, low autofluorescence, and extra-high transparency in the near-UV range used in many tests.
(401) 434-3107 • micropep.com
(859) 746-6447 • topas.com
Word Games: What’s a ‘Hybrid’?
Any molder will tell you there’s a difference in working with electric vs. hydraulic drives. Servohydraulic is still hydraulic; a hybrid machine is something different. Imprecise use of terms causes needless confusion.
U.S. Debut for Slimmed Down Electric Machine
NPE2024: Arburg’s debut of the 310-ton Allrounder 720 E Golden Electric extends the tonnage range of the electric series and marks the first global press premiere outside of Germany.
Consistent Shots for Consistent Shots
