New Modular Design Simplifies Temperature Control and Cuts Cost Per Loop
A brand-new physical package is said to take much of the headache and expense out of buying, installing, and maintaining temperature controls for machine barrels, thermoforming ovens, hot-runner manifolds, and a host of other plastics equipment. “No more crowded, messy, and cumbersome control panels.
A brand-new physical package is said to take much of the headache and expense out of buying, installing, and maintaining temperature controls for machine barrels, thermoforming ovens, hot-runner manifolds, and a host of other plastics equipment. “No more crowded, messy, and cumbersome control panels. No more components that lack status information. No more dealings with multiple suppliers for discrete components. No more paying for bundled components that you don’t need. Watlow’s integrated control loop just made the user’s life a whole lot simpler,” says Don Commare, product marketing manager for Watlow Electric Mfg. Co.
The firm’s new EZ-Zone ST control package with novel “integrated architecture” (patents pending) is said to be the first product to integrate temperature control, power control, safety shutdown, and power disconnect in a single package. It comprises a PID temperature controller already connected to a 40-amp solid-state relay (SSR) power switch, with the option of adding a properly sized heat sink, current measurement, over/under temperature limit control, mechanical contactor, and digital communications—all in one package. The buyer also has the option of adding a remote user interface.
A new paradigm
Until now, every temperature-control loop in a process typically required six separate components—PID controller, SSR, heat sink, current transformer, limit controller, and mechanical contactor—that had to be specified and purchased separately. (Watlow previously did not supply the current transformer or mechanical contactor.) These six components (not to mention the heater and sensor) had to be wired together and frequently required long runs of multiple wires from the control cabinet to the processing machine.
Watlow has changed all that by designing a modular system of components that snap together without wiring. This eliminates 10 to 12 wire terminations per zone (about half the usual number), saving a cost of several dollars per termination. And because all the components snap together into one compact unit—a smaller footprint than ever before, Watlow says—there is much less wiring between the control panel and the processing machine. Thus, even though the hardware components alone cost 20% to 25% more than conventional systems, Watlow is confident that its new product lowers the “total cost of ownership.”
Addressing the concept of “buy only what you need,” Watlow’s EZ-Zone ST system allows users to purchase only the number of zones they need, rather than in increments of six, 12, etc. Also, many previous single-loop controllers had the user display integrated with the PID controller, so one could not be purchased without the other. Now, for example, if a user wanted to view all zones on a remote display screen—even on the machine’s main display—there is no need to pay for displays at the control cabinet. And if one element of the system fails during use, you can replace only the affected module, not the whole system.
EZ-Zone ST is available in 1/16 DIN now and will also be offered in 1/32 DIN, 1/8 DIN, and 1/4 DIN configurations later in the year. The standard remote user interface (RUI) is a two-line, tri-colored LED display. Future models will offer enhanced LCD displays with English-language alarm messages instead of numeric codes.
Enhanced software, too
According to Commare, “Eighty percent of downtime related to temperature controls is for diagnostics, and only 20% is for replacing what’s broken.” With EZ-Zone ST, identifying the source of a problem is much easier, because all the modular components “talk to each other.” Watlow’s “Smart Power” diagnostics provide continuous self-monitoring and alarms.
PID temperature-control functions include continuous adaptive self-tuning as standard, as well as 40-step ramp and soak. A new quick-reset button on the RUI restores factory default settings. Also new is an “EZ” button on the RUI that allows users to select a preset function from a menu, such as a startup or shutdown routine.
Best of the Best
Water Temperature Control Upgraded and Integrated into Machine Control
Engel’s new eco-flomo temperature control system continuously monitors injection mold cooling and temperature control circuits, displaying pressure, temperature and flow rate values.
Temperature-Control Unit Enables Cycle Time Cuts
Control unit supplies cold water to the mold only in the cooling phase.
Follow These Best Practices When Working With Heat Transfer Fluids
industry 4.0
MMS ad
