What to See at NPE 2006: Polyurethanes and RIM
Despite the small number of polyurethane and RIM exhibitors, you will find some interesting new materials and equipment technology.One highlight will be a novel aliphatic PUR cast elastomer technology said to enable production of highly transparent parts with unique property profiles.
One highlight will be a novel aliphatic PUR cast elastomer technology said to enable production of highly transparent parts with unique property profiles. Developed by Bayer MaterialScience LLC to meet the increased global demand for high-quality ophthalmic products, the patented technology can make elastomers from extremely hard to very soft. They boast high impact, abrasion/scratch resistance, and light stability. They also have low viscosity at room temperature, 1.8:1 mix ratio, and fast demold.
High-pressure machines
New high-pressure RIM machines will be featured by Gusmer/Decker and Hi-Tech Engineering . Rimcell Lite high-pressure RIM machines from Gusmer/Decker sell for under $40,000. They feature PLC control, a self-cleaning GX15 mixhead (spray or pour versions), 10-gal day tanks, and a flow rate of 6 to 30 lb/min.
Hi-Tech’s EZRim high-pressure RIM machine is designed as a low-cost, simple alternative to low-pressure machines for production of gaskets or for lamination of sun visors, where PUR can replace epoxy. Operating with relay logic (no PLC), it sells for around $35,000, which is about 25% less than the company’s EcoRim unit and 30% to 45% less than others on the market.
TPE Made with 50% PCR Derived from End-of-Life Tires
Prism Worldwide has commercialized its first TPE with this type of recycled content based on its patented technology.
PIR/PCR Recycled Content and Biobased TPEs for Broad Range of Applications
NPE2024: Kraiburg TPE launching PCR/PIR content polyolefin-based TPEs and its expanded line of Thermolast R biobased TPEs.
Tracing the History of Polymeric Materials -- Part 29: Polyurethane
This material family has unparalleled versatility, not only in terms of the forms the material can take, but in the different ways in which it can be processed.
