Xenotest® Alpha+
The Xenotest Alpha+ provides reproducible and repeatable test results of lightfastness and weatherability using an air-cooled xenon arc light source and the ability to perform high irradiance tests up to 3 Sun. · Air cooled xenon lamp with 2200 Watt · XENOSENSIV sensors for measuring and controlling irradiance in the wavelength band 300-400 nm and Black Standard Temperature at sample holder level · Total exposure area: max. 1320 cm2 · Temperature control selectable by test chamber or Black Standard Temperature or both simultaneously · Air volume control to influence the temperature difference between test chamber and Black Standard Temperature · Specimen spray system · Color touch screen to show current test status and graphic display of the progression of your test parameters · Serial interface RS232, USB Slave Port, SmartMedia · Water supply with integrated water reservoir (capacity 70 l) · Software languages variable between German, English and French
  • Get Color Changes Right In Extrusion Blow Molding
  • Additive Masterbatches for Monomaterial PE Film Applications
    Ampacet’s Biax4CE portfolio of additives and white color concentrates designed for MDO-PE and BOPE applications.
  • The Steps to Consistent Color in Plastics
    Unlock the secrets to flawless color duplication in your production processes. Discover why expert color replication is paramount for maintaining quality, reducing costs, and ensuring client satisfaction and retention. Download now to gain insights that will revolutionize your approach to color control.
