Amcor Continues Assault on Glass with Hot-Fill PET Jars
Leading PET blow molder Amcor Rigid Plastics, Manchester, Mich. (amcor.com), is continuing its push to replace glass in hot-fill food products with new 24-oz, round, wide-mouth jars.
Leading PET blow molder Amcor Rigid Plastics, Manchester, Mich. (amcor.com), is continuing its push to replace glass in hot-fill food products with new 24-oz, round, wide-mouth jars. The stock container is a lightweight replacement for glass in pasta sauces, apple sauce, salsas, jams, jellies, and other food products filled at up to 205 F.
“Amcor has taken wide-mouth, hot-fill containers to a new level by combining our round wall design and novel blow-trim technology to create a glass-like PET container that has all the desirable consumer advantages,” says Ron McFarlane, principal engineer. Unlike standard stretch-blow molded containers, in which the neck finish is injection molded, Amcor reduces weight by blow molding the finish. A section above the finish, called the “blow dome” allows the preform to stretch adequately to form the critical features like threads during blowing. The blow dome is sliced off in a secondary operation. Besides saving resin, this technique saves cycle time and induces higher crystallinity in the finish. The 63-mm jar weighs just 51 g.
Amcor’s Performance Widemouth technology also uses a unique panel-less design. The bottle’s four horizontal ribs and stiff walls resist the vacuum as the product cools.
Amcor is not the first supplier of 24-oz, 63-mm hot-fill PET jars, which are already used for fruit sauces. Amcor says it has multiple customers interested in converting to PET for pasta sauces and fruit sauces.
Plastics Recycling Latam STD
