Aitrtech
mold cavity milling
It’s critical to keep in mind how your 3D-printed design translates to injection molding for both manufacturability and cost. (Photos: Protolabs)
Ten years ago, there was a broadly accepted and well-defined route that a product developer might travel to take a product from concept to actual part. Generally, that path would include 2D and 3D drawings of the components and their assembly, which would go through various prototyping stages in low-cost, low-volume manufacturing methods like CNC machining or cast urethane molding. Then the design would go into a more robust prototype rapid-tooling process and finally off to production.
Today, this is still a common and viable route, but thanks to technological advances in 3D printing materials and processes over the last decade, product developers now have far more real-world, engineering-grade options to consolidate and accelerate the early stages of product development. This has been a game changer for tech innovators over the years, but it also features some potential hidden pitfalls.
Virtually all moldable parts can be printed—but that isn’t true the other way around.
While injection molding remains the undisputed champion of high-volume plastics manufacturing—and is likely to hold that position for the foreseeable future—3D printing is rapidly making up ground in early-stage plastics manufacturing. Due to the different manufacturability constraints that exist with each respective process, part designers and molders can sometimes experience a disconnect between where they are in the process and how they want to manufacture a part.
When comparing potential manufacturing processes against criteria like price and lead time, there are many things to keep in mind. Each process requires different processing times, different types of materials and, most importantly, different part-design requirements and considerations. This article specifically covers part-design cost drivers. But first, let’s talk about a common cross-process design challenge that we at Protolabs see every day as one of the world’s largest injection mold manufacturers.
Designing for Moldability: a Cautionary Tale
Dexter is an engineer. He has an ingenious design solution to convert a five-part housing into two parts and save hundreds of thousands of dollars on tooling costs in production. Dexter designs the parts and sends them to his favorite 3D printing company to print the parts in SLS so he can do fit/form/function testing prior to tooling up the parts. When he receives his shipment, he’s ecstatic to find that his parts work wonderfully, and should be a perfect functional solution to his design problem.
Now that he’s ready to start moving into tooling stages, he quotes the parts for injection molding and bam! He’s told none of them is moldable. Dexter hangs his head in shame, walks back to his desk and starts to redesign the parts for moldability. This all-too-familiar tale represents the first of the four major cost drivers that this article will lay out. It is also arguably a root cause for many other cost drivers as well.
Keep in mind that 3D printing has far fewer design constraints than injection molding.
Not Starting with the Process in Mind
Dexter started with the solution in mind but didn’t consider the process. As 3D printing has become more and more popular—for good reason—many product developers are implementing it in stages that previously might have been completed in a different process. This is perfectly fine, if you keep in mind that 3D printing has far fewer design constraints than injection molding. The solution is to start by designing your part for molding, then take those moldable part designs and print them. Virtually all moldable parts can be printed—but that isn’t true the other way around. When you try to mold a part designed exclusively for 3D printing, your best-case scenario is that the manufacturer probably had to include many costly mechanical components in the mold in order to accomplish it. The worst-case scenario is that it just can’t be done.
Mold-Base Size
Our second cost driver is the base size of the mold. This is a common point of confusion in the manufacturing process, as it isn’t always evident how large or small the mold base is. For example, you might be able to make a 1 × 1 in. (25.4 × 25.4 mm) part in a straight-pull mold within a 4 × 4 in. (101.6 × 101.6 mm) mold base. Add an undercut to that part, requiring a side-action cam in the mold, and suddenly you might be into a 10 × 10 in. (254 × 254 mm) or larger mold base. In this case, base size and componentry drive mold cost. A single side action might add more than $1500 to the mold cost, so you should use best practices in design, such as pass-through cores to help you save on space and components.
Internal Componentry
We touched on this in our first two cost drivers, but outside of improper design and mold size, internal componentry is the key cost driver in an injection mold. What types of internal componentry? As we previously discussed, side-action cams are an obvious example. Some other examples include pick-out inserts, bolt-in inserts or steel core pins. Cams or inserts will typically increase your overall mold price by $1000 to $2000 per component, so keep that in mind in your designs.
mold finishing
Custom mold finishing helps bring cosmetic enhancements to molded parts.
Polish or Custom Finishing
Our last cost driver is polish or custom finishing for the mold. Most manufacturers will offer a range of finishes to choose from for your tools, including in-house, SPI or Mold-Tech equivalent, and they all have varying degrees of additional costs associated with them. In-house finishes will usually be the cheapest and are sometimes automated or come with the tool as milled.
When you try to mold a part exclusively designed for 3D printing, your best-case scenario is that many costly mechanical components were added to the mold—the worst-case scenario is that it just can’t be done.
These are great for prototype parts to test fit/form/function but might not carry the aesthetic properties needed for a production part. SPI or Mold-Tech equivalent finishes tend to be more expensive, so a good way to save time and cost is to wait to put these cosmetic finishes on the mold until after your design is finalized. Follow these tips, and you’re ready for production, regardless of whether and how you utilize additive manufacturing in developing your injection molding part and process.
ABOUT THE AUTHOR: Rob Young is a product leader for injection molding at Protolabs. He has more than eight years of experience in digital manufacturing and specializes in on-demand production and supply-chain optimization for Industry 4.0. Young started worked in applications engineering before holding multiple leadership roles working with customers. He came to Protolabs after working with early-stage startups at the Ina Mae Rude Entrepreneur Center and Center for Innovation Tech Incubator in Grand Forks, N.D. Contact: rob.young@protolabs.com;  877-479-3680;  protolabs.com.
Best of the Best
Molds & Tooling
processing tips
Injection Molding
Protolabs Accelerates Development Time for Covid-19 Contract Tracing Device
Protolabs helped a contact tracing and social distancing system move from idea to finished product in six weeks, permitting its manufacturer to get back to work and make thousands more of the devices that have subsequently allowed other businesses to come back online.
Additive Manufacturing
Protolabs CEO Discusses the Digital Age of Manufacturing
As the company reaches its 20-year milestone, Plastics Technology talked with Protolabs CEO Vicki Holt about what’s next for the innovative company.
Testing
Prototyping Specialist Upgrades Services For Short-Run Production Molding
Proto Labs, a “digital manufacturing company” known for its rapid injection molding prototyping services, has expanded its injection molding capabilities to address the market for short-run “on-demand” manufacturing.
3D printing machine trainings
