WSB Gravimetric Blenders
Colloidal Silica Processing Aid Slashes Molding Cycle Times
Ultra-fine synthetic silica particles have been shown in laboratory and commercial field trials to reduce injection molding cycle times by 20% to 30% in polypropylene, filled and unfilled nylon, PBT, and ABS.
Ultra-fine synthetic silica particles have been shown in laboratory and commercial field trials to reduce injection molding cycle times by 20% to 30% in polypropylene, filled and unfilled nylon, PBT, and ABS. This processing advantage is accompanied by retention and even improvement of key physical properties. Other reported benefits are improved color dispersion
and reduced flow lines and surface defects. What’s more, the silica additive is said to mix easily with resin pellets in a blender, so melt pre-compounding is not required.
Nan-O-Sil ASD additive is high-purity, amorphous, colloidal silica in the form of a white powder. The spherical particles range in size from 0.02 to 0.55 microns (20 to 550 nanometers). Nan-O-Sil ASD is manufactured and marketed by Energy Strategy Associates, Inc., which has been working with technical consulting and R&D firm Rheo-Plast Associates to develop applications for this additive. Headed by Dr. Pravin L. Shah, Rheo-Plast specializes in polymer rheology and its application to extrusion, injection molding, and compounding of engineering plastics and blends/alloys. Rheo-Plast conducted laboratory testing of Nan-O-Sil in a variety of resins. Dr. Shah supplied the test results to Plastics Technology for this article.
EXPERIMENTAL RESULTS
Injection molded sample bars were obtained by first tumbling resin pellets with Nan-O-Sil ASD for 15 min in a Conair blender. The additive coated the pellets well and uniformly, Shah reports.
Table 1—Faster Injection Molding Cycles With Nan-O-Sil ASD
Material w/
0.8% Nan-O-Sil
Avg. Cycle Time Reduction
PP, unfilled
22%
Nylon 6, unfilled
24%
Nylon 66, 33% glass
32%
PBT, unfilled
26%
ABS, unfilled
25%
The most dramatic results with Nan-O-Sil ASD are the cycle-time reductions for PP, unfilled nylon 6, glass-filled nylon 66, unfilled PBT, and ABS (see Table 1). The additive also shows utility as a reinforcing filler that can raise the stiffness of PP and both stiffness and strength of nylon 6 and PBT (Tables 2 to 5). Depending on the resin and the amount of Nan-O-Sil used, there was little or no sacrifice of other properties, such as elongation or toughness.
In glass-filled nylons, using larger amounts of Nan-O-Sil ASD appears to have potential for reducing the amount of glass fiber required to improve strength and stiffness. One trial compared the physical properties of 13% glass or 10% Nan-O-Sil in nylon 6. As shown in Table 4, colloidal silica imparted a greater increase in tensile strength and flexural modulus than did the glass fiber. According to Shah, an in-depth study of combinations of Nan-O-Sil ASD and glass fiber is under way and results will be published next year.
HOW IT WORKS
Although the precise mechanism by which Nan-O-Sil ASD reduces cycle times and improves strength properties of molded plastics is still unclear, Shah says the additive has been shown to work at low addition levels of 0.4% to 0.8% as a heat sink to reduce the amount of cooling required during molding. Based on Brabender torque rheometer data, he also postulates that the additive works as a processing aid to reduce the shear gradient at the gate and facilitate melt flow orientation.
Also not clearly understood at present is the apparent melting-point depression observed in PP, though no such effect was evident in nylon. Further work is under way to determine the additive’s behavior in melt processing.
Table 2—Nan-O-Sil ASD in Polypropylene
Material
Tensile Str. @ Yield, psi
Elongation @ Yield,
Tensile Mod., psi
Gardner Impact, in.-lb/in.
Flexural
Modulus, psi
Flex. Str., psi
MFI, g/10 min
Melt Point, C
PP Control
3000
9.7
145,000
2.18
112,000
3350
8
168
PP/0.4% Nan-O-Sil
3020
8.9
151,000
2.15
122,000
3570
8.2
163
PP/0.8% Nan-O-Sil
2930
8.2
144,000
2.12
118,000
3520
8.3
160
TABLE 3—Nan-O-Sil ASD in Nylon 6
Material
Tens. Str. @ Yield, psi
Elongation @ Yield, %
Tensile Mod., psi
Gardner Impact,
in.-lb/in.
Flexural Modulus, psi
Flexural Strength, psi
HDT @
66 psi, F
Nylon 6 Control
8710
4.5
315,000
2.18
224,000
9300
140
Nylon 6 + 0.4%
Nan-O-Sil
8760
4.5
320,000
2.18
227,000
9330
140
Nylon 6 + 0.8%
Nan-O-Sil
9020
4.6
320,000
2.15
237,000
9840
140
TABLE 4—Nan-O-Sil ASD Vs. Glass Fiber in Nylon 6
Material
Tensile Mod., psi
Gardner Impact,
in.-lb/in.
HDT @
66 psi, F
Nylon 6 Control
8710
4.5
315,000
2.18
224,000
9300
140
Nylon 6 + 13% Glass
8760
4.5
320,000
2.18
227,000
9330
140
Nylon 6 + 10%
Nan-O-Sil
9020
4.6
320,000
2.15
237,000
9840
140
Table 5—Nan-O-Sil ASD in PBT
Material
Tensile Modulus, psi
Gardner Impact,
in.-lb/in.
Flex. Str., psi
MFI, g/10 min
PBT Control
7400
3.6
145,000
2.18
355,000
3350
8
PBT+ 0.4% Nan-O-Sil
7400
3.4
151,000
2.14
374,000
3570
8.2
PBT+ 0.8% Nan-O-Sil
7600
3.2
144,000
2.1
380,000
3520
8.1
Masters of Blending
Testing
Try This Alternate Method for Heating Your Torque Rheometer
Rheometers are generally not on all the time. And most users have found that the first test run in the instrument after heating up is not very reliable and is usually discarded. Try this method instead.
Testing
Upgrade to Accelerated Artificial and Natural Weathering Testing
NPE2024: Atlas S³T system is designed for the company’s Weather-Ometer Ci4400 and Ci5000 instruments.
Testing
Inline Inspection System for Wood Plastic Composites
Pixargus’ ProfilControl 7 DX WoodPlasticComposites measure all dimensions and geometrics, including deep grooves.
Blow Molding
How Inline Vision Inspection Can Minimize Scrap in Molding
