EXTRUSION: Understanding The Barrier Gap
All barrier screws are not created equal, and the barrier length and gap can be one of the reasons.
Since barrier screws are being used in so many applications, it’s important to understand all the variables controlling their performance. One of those is the barrier gap. I see all kinds of variations that often do not match the other features of the screw design. I assume many designers have their own calculation to determine the gap, as literature on the subject offers little in the way of guidelines.
Barrier screws are designed to allow melted polymer to move from the solids channel to the melt channel by passing over the undercut barrier. This provides a number of performance advantages that have been described in many articles. But how are the barrier gap, length, and width determined? All three of the dimensions are important.
There are two forces that account for the movement of the polymer across the barrier from the solids channel to the melt channel. First (and usually most important) is drag flow, and second is the pressure difference between the two channels. Since the pressure difference requires very complex computer simulation to approximate its value, most screws will be designed without benefit of that information.
However, not having an estimate of the pressure difference between the channels does not usually lead to a large error except for some very soft polymers. The pressure is typically higher in the solids channel and adds to the drag flow, thereby increasing the flow rate. So drag flow over the barrier can be matched to the calculated drag flow of the screw (QD) for determination of a minimum barrier gap. A simple drag-flow equation for flow between parallel plates (QD=V0 H/2) can be modified to calculate a drag flow (QB) over the screw barrier. This can be rewritten to fit the barrier as:
QB= 1/2(Rev/sec x (Pi)2 x (Screw Dia)2 x gap x helical length)
By inserting a helical length for the barrier and substituting the drag flow of the screw (QD) for (QB), a minimum barrier gap can be determined:
Gap=QD/[1/2( rev/sec x (Pi)2 x (Dia)2 x helical length)]
The width of the barrier flight can negatively impact output, as the wider the flight, the greater pressure drop across the barrier flight. But since most barrier flights are relatively narrow, it seldom has an overriding effect on the design. If necessary, it can also be determined by a modification of the pressure-flow equation, but that requires determination of the viscosity in the gap.
The output of very few smooth-bore single screws exceeds drag flow, so this provides a minimum value for the gap. It is not suitable for grooved-barrel single-screw extruders, where the output typically exceeds drag flow and the pressure flow over the barrier can be significant.
The important thing to note is that this simple calculation can help avoid barrier flights that restrain the output of an otherwise suitable barrier design, and can give some guidance to control excessive gaps. It also shows that the helical length of the barrier is as important as the undercut of the gap.
It would seem that a short barrier length would need a large barrier gap; or conversely, a long barrier length would need a very small barrier gap. Unfortunately QB is not a complete solution because the barrier gap should also approximate the melting rate in the channel or the melt-film thickness. Too large a gap may allow solids to pass over, while too small a gap will restrict them and a melt pool will form in the solids channel, disrupting the melting.
Calculating the melt-film thickness is difficult without a thorough knowledge of the polymer properties and is usually done by computer simulation, although empirical formulas can be used to get very good approximations. Since that information may not be available to some screw designers, the final gap determination is still subject to some adjustment, but QB provides a minimum value.
The solution, then, to a reasonable approximation for the barrier flight has to come from experience and by increasing the gap using some multiple of the calculated gap. Underestimating the gap usually has more severe consequences than overestimating it.
ABOUT THE AUTHOR
Jim Frankland is a mechanical engineer who has been involved in all types of extrusion processing for more than 40 years. He is now president of Frankland Plastics Consulting, LLC. Contact
jim.frankland@comcast.net or (724) 651-9196.
The Role Barrel Temperatures Play in Melting
You need to understand the basics of how plastic melts in an extruder to properly set your process and troubleshoot any issues. Hint: it’s not about the barrel temperature settings.
Read MoreThe Right Way to Design Vents in Single-Screw Extruders
Designing vents for single-screw extruders requires understanding of polymer flow in the screw channels. Some designs are more effective than others. Here are some guidelines.
Delivering Increased Benefits to Greenhouse Films
Baystar's Borstar technology is helping customers deliver better, more reliable production methods to greenhouse agriculture.
