WSB Gravimetric Blenders
New Pressure Transducer For Food & Medical Extrusion
Processors of extruded products for food or medical applications have a new option in pressure transducers that gives improved performance at competitive cost.
Processors of extruded products for food or medical applications have a new option in pressure transducers that gives improved performance at competitive cost. Food and medical applications cannot use the most common sort of transducer because it is filled with a very small amount of mercury. These traditional transducers are said to be the most accurate, stable, and cost-effective pressure sensors for the general extrusion market. Alternative “non-toxic” transducers all present significant compromises in performance and/or cost. But a new oil-filled sensor that meets FDA and USDA requirements is said to overcome previous performance limitations at a relatively low cost.
Oil-filled lasts longer
The new oil-filled PT418 Series transducers from Dynisco, LLC in Franklin, Mass., completes the line of non-toxic transducers available from this company. Dynisco already offers the two other non-mercury types—NaK-filled and push-rod models. Up to now, oil-filled types had a significant drawback, according to Douglas Joy, Dynisco’s director of marketing. The mineral-oil filler, which transfers pressure from the surface diaphragm to the strain gauge, gradually degrades when exposed to high temperatures. As a result, oil-filled sensors typically require frequent calibration checks and may need replacement more often than is acceptable to processors. Joy says tests show that standard oil-filled sensors can fail to operate within specifications after as little as 4 months at 570 F.
Dynisco reportedly has overcome this limitation with a new oil fill material and proprietary processing techniques that result in two to three times longer transducer life. Joy says the new PT418 series has operated within specification for almost a year now. Its maximum operating temperature is 617 F, though the recommended limit for optimum life span is 527 F. Its accuracy (combined error) is rated at ±0.5% with repeatability of ±0.2%. At a price of $690 to $1400, these improved oil-filled models cost a few dollars less than mercury-filled models of comparable accuracy.
Changing the balance
The arrival of longer-lasting oil-filled transducers changes the balance of cost-effectiveness among the three types of non-toxic sensors. Push-rod transducers have about the same accuracy and repeatability specs as oil-filled sensors, and they cost about the same, too. Because they use a metal rod in place of the fluid filling, they can have virtually unlimited life if handled properly, and they can be used at temperatures up to 750 F. However, one big disadvantage of push-rod sensors is that they require careful installation in order to function accurately, and they are vulnerable to pressure spikes due to bumping or vibration. They also experience more zero-shift error in response to changes in either ambient or process temperature than other types of transducers. And because of their thicker diaphragms, push-rod transducers are less accurate than other sensors at low pressures (e.g., 250 to 500 psi).
The remaining category of non-toxic transducers has a sodium-potassium (NaK) liquid fill. They are up to twice as accurate and repeatable as push-rod and oil-filled types. They are also the most sensitive at low pressures and can handle the highest temperatures (up to 1000 F). Their fill does not degrade over time, and they are the least sensitive to temperature-induced zero-shift error. The main disadvantage of NaK sensors is cost (around $1000 to $1200) and their lack of an explosion-proof rating.
Masters of Blending
Sponsored
Single vs. Twin-Screw Extruders: Why Mixing is Different
There have been many attempts to provide twin-screw-like mixing in singles, but except at very limited outputs none have been adequate. The odds of future success are long due to the inherent differences in the equipment types.
processing tips
