How United Plastics Became A Quick-Change Artist
United Plastics Corp., a small profile and sheet extruder with 125 employees in Mount Airy, N.C., combines an almost unbelievably diverse product mix (it has some 5000 dies in active use) with the ability to change over individual extrusion lines four or five times a day.
United Plastics Corp., a small profile and sheet extruder with 125 employees in Mount Airy, N.C., combines an almost unbelievably diverse product mix (it has some 5000 dies in active use) with the ability to change over individual extrusion lines four or five times a day. The company also has vertically integrated raw-material blending and compounding to fill its long menu of short-order recipes.
United’s 24 Davis-Standard extrusion lines include five for flexible sheet (20- to 96-in. wide), a dozen for rigid PVC profiles, and seven for flexible PVC profiles. Eighty-five percent of its production is vinyl; the rest is PP, TPO, styrenics, and EVA. It pulverizes, blends, colors, reclaims, and compounds its own raw materials.
United spent most of its 58 years belonging to a series of giant global manufacturers. It was founded in 1946 as Carolina Industrial Plastics and originally extruded vinyl clotheslines. It was acquired in 1952 by Essex Wire & Cable, which converted it to extrusion of black vinyl tape for wire wrap.
In 1972 Essex was bought out by United Technologies Corp., and the Mount Airy plant became part of UT’s Automotive Group. It expanded into flexible PVC gaskets and seals for cars. By 1992, UT Automotive was sold and split up. The Mount Airy plant was bought by an investment group in Detroit, which sold it two years later to United Plastics managers and a group of Mount Airy investors.
When the hometown team took over, 65% of United Plastics’ sales were in automotive. Eight years later, the company has trimmed its dependence on automotive to only 35% to 40% of sales. Products that have grown to replace the automotive business include foamed and woodgrain-pigmented PVC “lumber” profiles, TPO sheet for roofing, and EVA sheet for sound deadening. Its product slate of small profiles also includes rigid PVC door and window parts, two- and three-layer coextrusions, living hinges, and flexible PVC gaskets and trim. Most of the dies would fit in the palm of your hand, and all 5000 of them fit into small wooden cubbies lining two walls of the plant’s die shop.
Five changes a day
United cuts almost all its dies in-house and has four full-time CAD engineers to design them. The dies are especially short because that makes them easy to change. United may run a profile for only 3 to 4 hours, whereas most custom profile extruders want jobs that run for days or weeks. An extruder at United Plastics may change dies four or five times in 24 hr. Explains Kenneth Roush, United’s president, “Our short dies would burn profiles on longer runs, but they’re easy to set up for short runs.” Changing a non-calibrated flexible PVC line takes about 20 min; a calibrated rigid profile line may take 90 min.
Quick changes have paid off. “While other processors’ business has been shrinking, we’ve been growing,” says Roush. United runs all its lines around the clock, seven days a week for sheet and a five days a week for profiles.
Recycling joins the mix
Perhaps as atypical as the extraordinary number of products it makes is United’s vertical integration in raw materials. The company does its own short-order dry blending and color mixing. “We make over 300 approved colors for the automotive industry,” Roush notes.
Last January, United added recycling to its raw-material arsenal, so it now reclaims PVC carpet backing to create new compounds. United’s 12,000-sq-ft reclaim plant includes a large Vecoplan ReTech shredder, a Cumberland granulator, and three elutriators (air separators) from Sterling Elutriation in Forest, Va. The carpet scrap is shredded, pulverized, and then sent through all three elutriators in succession. The elutriators separate the calcium carbonate-filled flexible PVC backing from the lower-density carpet face fibers at up to 2000 lb/hr. Face fibers are compacted and shipped out for waste-to-energy incineration.
Reclaimed PVC crumb is extruded into black PVC sheet that is used as an underlayer in new carpeting. “Our skills as reclaimers and compounders let us compete against much bigger companies,” says Roush. “We stay ahead by innovation and diversity.”
Use Interactive Production Scheduling to Improve Your Plant's Efficiencies
When evaluating ERP solutions, consider the power of interactive production scheduling to effectively plan and allocate primary and secondary equipment, materials and resources on the overall production capacity of the business and conclude that this is a key area that cannot be overlooked.
Read MoreReduce Downtime and Scrap in the Blown Film Industry
Read MoreHow Screw Design Can Boost Output of Single-Screw Extruders
