Modern Machine Shop ad
Westchester Plastics Adds Capacity
Significant expansion at its Wapakoneta, Ohio, plant.
Ametek Westchester Plastics, an independent compounder of thermoplastics, has significantly expanded capacity at its Wapakoneta, Ohio, plant. A new compounding line is based on a 92-mm Coperion ZSK Mega Compounder Plus twin-screw extruder with 44:1 L/D, 1250-hp drive, dual vacuum venting, dual side-feeder capability, and liquid injection capability. The pelletizing section includes rare-earth magnets and electronic metal detection.
Another addition is a new 40-mm, 44:1 twin-screw CXE40 high-speed/high-torque model from Century Extrusion for development and production use. It has 1200 rpm max. speed and the same other features as cited for the larger machine. An existing 70-mm, 9-barrel Coperion Super Compounder was upgraded and lengthened by two barrel sections. (Ametek plans a similar upgrade for a 92-mm Coperion Super Compounder in the next few months.) Also, an existing #4 Farrell Continuous Mixer line was rebuilt and upgraded with post-blending and drying.
  • What to Know About Your Materials When Choosing a Feeder
  • Configuring the Twin Screw Extruder: Part 4
  • Improving Twin-Screw Compounding of Reinforced Polyolefins
