Climbing like a gecko thanks to molded silicone pads
The science of bio-mimicry seeks inspiration for new technologies in nature, and it’s hard to find a better natural climber than the gecko.
The gecko’s unique feet, which can scale smooth, vertical surfaces without surface tension, attracted the Defense Advanced Research Projects Agency’s (DARPA) Z-Man program, which seeks to give U.S. soldiers “maximum flexibility for maneuvering and responding to circumstances.”
A “novel polymer microstructure technology” was developed for DARPA by the Draper Laboratory of Cambridge, Mass., and built into paddles that allowed a 218-lb man, carrying a 50-lb pack, to go up and then down a 25-ft sheer glass wall, “with no climbing equipment other than a pair of hand-held, gecko-inspired paddles.”
In a paper published in the Journal of the Royal Society, the Draper scientists describe their advance as a “wedge-shaped gecko-like synthetic adhesive that exhibits several gecko-like properties simultaneously.” These include:
- Zero force at detachment
- High ratio of detachment force to preload force
- Non-adhesive default state
- Ability to maintain performance while sliding, even after thousands of cycles
“Individual wedges independently detach and reattach during sliding, resulting in high levels of shear and normal adhesion during drag,” the paper notes. They keep the stickiness too, retaining 67% of the initial adhesion and 76% of initial shear after 30,000 “attachment/detachment cycles” without cleaning.
The gecko-like pads were molded from a silicone, polydimethylsiloxane, using an epoxy (SU-8 photoresist) mold in a lithography process.
After the molds were created, silicone-based elastomers were cast under vacuum, spun to a desired backing layer thickness, heat cured and pulled out of the mold by hand.
Not exactly automated, and not a production tool by any stretch. The researchers noted that the molds typically lasted for only 10 “cast-and-peel” cycles before “cracking”, “delaminating” or “clogging” due to residual polymers left in the cavities. Time for some P-20 tool steel and a mold-release agent, perhaps?
Part 3: The World of Molding Thermosets
Thermosets were the prevalent material in the early history of plastics, but were soon overtaken by thermoplastics in injection molding applications.
