Hydrolysis-Resistant PBT that is Also Laser Transparent 'Shines' in Demanding Automotive Engine Application
Actuators for new automotive diesel engine series made with a Lanxess PBT that is hydrolylis-stabilized and allows for laser transmission welding.
Not all PBT’s are created equal—particularly those used for demanding automotive applications, such as optimized combustion process swirl control actuators, part of the air management systems in combustion engines responsible for controlling the air supply to the intake module and, at the same time, ensuring sufficient air turbulence. Such actuators help to optimize combustion processes and so play a key role in ensuring that the engine is highly efficient, which is ultimately reflected in high fuel economy and correspondingly low consumption figures.
We recently heard from Lanxess regarding the use of one of its specialty PBT compounds that was selected by a German automotive manufacturer for a new automotive diesel engine series. PBTs are generally used for such actuators because of their dimensional stability. But, since an actuator can also be exposed to a hot and humid climate in the engine compartment, a hydrolysis-stabilized material is required. In this particular application, laser transmission welding (a major trend in plastic housings) was selected as the joining method because it produces strong, lint-free and tight welds.
Lanxess' hydrolysis-resistant, laser transmissable PBT used in automotive actuators
However, the combination of hydrolysis resistance and laser transparency is a conflicting target on the material side. “As such, our Pocan B3233HRLT is already something very special with which we can serve this trend,” said Jean-Marie Olivé, an application development expert in Lanxess’ High Performance Materials (HPM) business unit. The actuators are developed and manufactured by Sogefi Air & Cooling SAS in Orbey, France. The company is part of Sogefi S.p.A., an Italian corporate group that is among the world’s leading providers of filter systems, flexible chassis components and air intake and engine cooling systems for vehicles.
In principle, a 30% glass-reinforced nylon 6 or a non-laser transmissible (LT) 30% glass-reinforced PBT would also be conceivable. However, nylon is less dimensionally stable due to moisture absorption, and in the case of non-LT PBT, one would have to switch to a less modern joining process, e.g. screwing with a seal or ultrasonic welding (lower weld seam strength, lint formation).
“The special feature of this application is certainly modern laser transmission welding. This is already something special with our PBT HR materials, since normally the transparency is not sufficient to achieve a good weld seam. In addition, we have a laser-transparent black here, which not everyone can do either. Normally, soot-filled black components absorb the laser radiation completely, so that no transmission welding is possible,” explained Olivé.
Laser transmission welding is ideally suited to the cost-effective and gentle production of very small components with complex geometries, making it perfect for the trend toward miniaturized electrical and electronic functions. The procedure uses the energy of laser light. A laser beam passes through a laser-transparent component and is absorbed by a second component – usually black-pigmented – underneath. The absorption creates heat, which melts the surface of the second component. In turn, heat conduction softens the surface of the first component, allowing a strong weld seam to form between the two components. In the case of the new  actuator, the laser transparent part is made from Pocan B3233HRLT with laser transparent black coloring, while the absorbing housing half is made from Pocan B3233HR.
The outstanding resistance of B3233HRLT to hot and humid environments is demonstrated in the SAE/USCAR-2 Rev. 6 long-term test, which is conducted in accordance with a standard set by the American Society of Automotive Engineers (SAE) and considered to be among the world’s most demanding tests of the hydrolysis stability of plastics. A finished part is exposed to strong temperature changes at relative humidities of up to 100% over numerous cycles.
Said Olivé, “In specimen tests conducted in similar conditions, our compound fulfills the requirements of Class 3 and so can withstand temperatures up to 125 C/257 F.”
Process Cooling
Plastics Recycling Latam STD
Plastics Size Reduction
Injection molding machines
2025 Twin Screw Report
Automotive
PEEK for Monolayer E-Motor Magnet Wire Insulation
Solvay’s KetaSpire KT-857 PEEK extrusion compound eliminates adhesion and sustainability constraints of conventional PEEK or enamel insulation processes.
Automotive
Of all the trends you can see at NPE2024, this one is BIG. Not only is the auto industry transitioning to electrification but there are concerted efforts to modify the materials used, especially polymers, for interior applications.
Carbon Fiber Reinforced Nylon 12 for Injection Molding
CRP Technology’s new composite is 100% recycled from Windform XT 2.0 IMG industrial 3D printing material.
Injection Molded Tape and Resin “Sandwich” Technology Debuts
During its Mobility Days in Austria, Engel and KTM Technologies debuted an all-plastic molded motorcycle seat base produced via a tape-sandwich process that can run in a standard molding process.
processing tips
