Twin-Screw Elements Offer Option to Kneading Blocks
Said to be less harsh while creating 'turbulent mixing' without stagnation.
Twin-screw compounding machine builder Steer introduced at NPE2015 a new series of screw elements that reportedly are suited to replace kneading blocks in certain applications.
Called Melt Formation Elements (MFEs), they will be used on Steer's Mega and Omega co-rotating twin-screw platforms to reportedly provide compounders with improved reliability, reduced wear and increased uniformity of melting and mixing.
Steers says the elements are designed to combat a series of problems faced by compounders of masterbatch, engineering plastics and difficult-to-process materials, notably: high wear; degradation during melting; uncontrolled breakdown in the process and transmission section; and improper material flow causing pressure peaks, which in turn leads to shear peaks that create torque instability and re-agglomeration,
As Steer explains it, while conventional kneading blocks (right handed, left handed or neutral) are effective at dispersive mixing, they are too harsh for many applications. This is because they present a perpendicular face to the flow causing melt stagnation and large pressure and shear peaks during melting.
Notes Dr. Babu Padmanabhan, Steer's managing director & chief knowledge officer, “The MFEs are designed to create turbulence to the melt flow without stagnation. They can replace conventional kneading blocks that suffer from lack of shear uniformity completely removing any right angled face to the melt flow.”
More Than a Compounder: They Have the Science to Create New Custom Materials
Small Batches, Big Success
With no minimum order and an impeccable record of on-time delivery, Precision Color Compounds is becoming a force in the color masterbatch business.
