Communication Is Key in Designing Blown Film Dies
Over the years I have bought, designed, or helped design quite a number of blown film dies.
Over the years I have bought, designed, or helped design quite a number of blown film dies. After few go-arounds, it amazed me how often the process of designing a die was treated as “magic,” with the thought that only a few anointed “die wizards” could actually do the job. Not so.
That being said, there are a few things these wizards do need to know before tackling your project. And if the one you’re working with does not ask for them, find another wizard.
First, a few basics: A die can run one material at one temperature and one output rate perfectly…if it is designed perfectly. To put it more scientifically (it is science, after all), a die is designed for one volumetric throughput of a material with specific viscosity characteristics. If you ask anything more of a die, something will be compromised somewhere. (Of course, some die designs are more forgiving than others).
The first thing your die designer needs to know is what are you planning to run on it, and how fast. This may sound obvious, but sometimes it is not communicated well. It is not enough to tell a designer, for example, that you’ll be running an 18% 2-MI EVA with a 1-MI HDPE in a 10/90 layer ratio at 1000 lb/hr. That information alone won’t get you the die you need. Rather, the die designer will need the actual rheology curves (tabulated raw data is even better) for the specific resin blends you are running. (Please note: It is the rheology of your blends that counts.) Provide them this rheological data at temperatures that straddle your operating conditions (typically three temperatures).
Always have a confidentiality agreement in place before sharing information with your designer. But if you have a product that is truly super-secret, remember that the designer generally only needs the rheology data, and throughput rates. The designer does not need to know if you’ll be running LDPE or LLDPE (though the rheology curves should provide a pretty good idea, in any event).
After you have given your die designer what he needs, there are some things you need to get from him—guarantees. The more general ones are listed here:
- Gauge uniformity: This should be defined up front. Is it two or three standard deviations total range? More importantly, how is it measured? By a micrometer of a given footprint? Every inch? With a beta gauge or a capacitance gauge on the bubble, or in the lab? At a certain speed/width, of data collection? The point is to be clear and specific in writing. This should only concern CD or TD variation, as the die designer has little control over the MD variation of your process.
- Layer Uniformity: Almost all coextrusion blown film dies are actually multiple dies “stacked” together in one manner or another. So each “die” module in the stack must be evaluated on its own. The rules are the same as outlined above. The methods of measuring layer thickness and uniformity are different, but should also be defined up front in writing. When defining layer thickness do not forget to specify volume vs. mass, as there can be a wide range of densities between polymers.
- Output vs. pressure drop and gauge uniformity: This is a good one to test your die designer and his software. When you get the die up and running, how close did he come to his calculated values? No one is perfect, but…. To be fair, when calculating the pressure drop, the rest of the system needs to be subtracted when throughputs are changed.
- Get drawings: The time to get an agreement to have detailed die drawings, both external and internal, is before placing the order. Most die makers will resist giving internal dimensions. (After all, this is the magic.) Sometimes you can get this information if you let them leave out the spiral, or distribution, section. This has worked for me in the past, as the non-distribution areas are my greatest interest as a processor. And if I really want the other dimensions, I can get them (and often have) by measuring them myself.
I recommend taking the die apart when it is first delivered, even though this may be an unpleasant, seemingly unnecessary process. Doing so will give your maintenance people the opportunity to see and learn what will be involved in their future work, and to prepare for it. Plus you can find any defects. And if the die maker refused to supply dimensions, you can get them at this time. (Or, a local machine shop has all the measuring tools and would be happy to do it for you for a marginal fee.)
About the Author
Eric Hatfield is manager of technology implementation at specialty film processor Clopay Plastic Products, Mason, Ohio. He can be reached at ephatfield@clopay.com.
Film Extrusion: Boost Mechanical Properties and Rate of Composting by Blending Amorphous PHA into PLA
A unique amorphous PHA has been shown to enhance the mechanical performance and accelerate the biodegradation of other compostable polymers PLA in blown film.
Read MoreFlexible-Film Processor Optimizes All-PE Food Packaging
Read MoreFiltration System Helps Film Processor Manage Recycled Material Mandates
Global film processor RKW teams with Nordson to enable it to process blown film with high recycled content.
Read MoreLeading Cast Film Processor Adding Blown Film Capacity
Malpack adds two multilayer blown film lines for agricultural, stretch hood and shrink films.
