Aitrtech
Cures for Common Hot-Runner Wiring Problems
In the challenging environment of the last several years, manufacturers are looking inward to improve their manufacturing processes, streamline their supply chains, lower maintenance costs, andimprove their bottom lines.
Jody Williquette, National Business Development Manager, Electrivert, Inc.
In the challenging environment of the last several years, manufacturers are looking inward to improve their manufacturing processes, streamline their supply chains, lower maintenance costs, and improve their bottom lines. Injection molders are frustrated with the costs associated with failing power and thermocouple cable assemblies in hot-runner systems. These costs include tool or controller damage, cable repair or replacement, loss of production, strained customer relations, overtime expenses, and much more.
Power and thermocouple assemblies come in a variety of configurations, many of which are based on rectangular connectors similar to those made by Harting, Inc., Elgin, Ill. (hartingusa.com). Unfortunately, in many cases components from different suppliers are mixed and matched in the same assembly and/or application. This contributes to increased failure rates. Key factors are connector manufacturing quality, design tolerances, cable types, cable gauges and strain-relief selection. To minimize this, you need properly sized, UL-listed connector and cable components.
Failures on the production floor are simple to understand. Uncovering their root causes and  solutions takes a bit more research and insight into cable assembly construction and use over their life cycles. Common failure modes and remedies are summarized below. In reviewing them, keep in mind the following key principles:
•Proper cable installation and application will reduce downtime, repair and replacement costs.
•Reliability is often lacking in cable assemblies produced under current industry practices.
•Current industry design standards need to be re-evaluated.
PIN PUSH-OUT/PIN BREAKAGE
Pin push-out decreases or eliminates contact with the mating pin. Some causes are:
•High number of mating cycles.
•Improper alignment and/or forcing the connectors together.
•Tolerance mismatches between connector manufacturers.
•Loose tolerances from the manufacturer.
•Connector damage due to over-current or heat.
The simplest solution to reduce or eliminate pin push-out or breakage is to use high-quality components from a respected manufacturer. Avoid using multiple brands of connectors unless you have verified that there are no tolerance issues.
Machined contacts can reduce the occurrence of pin-push out and are more durable than stamped or formed contacts. Since machined contacts are solid, they provide improved electrical characteristics due to greater contact surface and tend to stay fixed in the connector more reliably. Female machined contacts have more “wall” material than stamped or formed contacts. This improves pin holding forces between male and female contacts. They can also withstand greater amounts of abuse. Additional benefits of machined contacts are:
•Uniform thermal transfer, reducing hot spots and pin burnout.
•Uniform contact surfaces, improving current characteristics.
•Greater resistance to unintentional abuse, minimizing pin breakage.
Connector misalignment can cause pin push-outs and breakage. Guide pins and bushings are very inexpensive, easy to install, and reduce the chances of connector misalignment. Guide pins simply replace the connector-insert mounting screws.
Upgrade your connectors to a newer design. A common older standard for hot-runner power cables is a 25-pin connector with crimped pins. This can be switched out for a newer 32-pin crimp connector that fits a 16B sized hood and housing. This conversion offers three very important benefits:
1. It uses robust machined contacts vs. smaller, stamped/formed D-Sub contacts typically found in the 25 pin connector.
2. It is rated for 16 amps versus the 10A rating of the 25-pin connector.
3. The newer design holds the pins in more reliably.
Lastly, standardize on screw terminal connectors or upgrade to overmolded cable assemblies. These “encapsulate” or “capture” the pins so push-out is not possible. Broken pins can be drastically reduced. The 24-pin screw-terminal connector used on hot-runner thermocouple cable assemblies is an excellent example. By adding “coding pins,” it is possible to standardize on this connector for power and thermocouple cable assemblies.
PIN BURN-OUT/SHORT CIRCUITS
Pin burn-out is a catastrophic connector failure caused by current overload or a short circuit. Using a 10-amp connector for a 15A circuit is a major contributing factor. The typical 25-pin crimp connector used in hot-runner power cable assemblies is rated for 10A.
Other causes include cable failures, broken pins, and pin push-out. Reducing costs associated with pin burn-out is simple: Use UL-listed connectors and cables rated for at least 15 amps.
CONNECTOR DAMAGE
Mechanical damage can be a more difficult issue. Connectors get dropped, caught in the tools, run over by forklifts, and subjected to other abuses. Broken latches, damaged latch “bails,” cracked or smashed hoods, and broken mounts are just a few examples of connector damage found on plastic injection presses.
Latches are damaged by excessive physical loading on the latch while it is plugged in, by being latched while there is a misalignment issue, or by random physical abuse. Switching from top-entry (straight) to side-entry (90°) hoods may help reduce mechanical loading on the latch assemblies. This may not be possible in all cases, due to physical constraints of the system. Most standard  hoods and housings come in both single-lever and dual-lever designs. Dual-lever designs distribute the physical load better. Guide pins and bushings also can be installed to prevent connector misalignment.
Overmolded rectangular cable assemblies are an additional option. Their key benefits are:
•They eliminate conductor stress and contact push-back to help reduce system failures.
•Their 250-lb pull-out force rating eliminates cable pull-out.
•Omni-directional flex-strain relief reduces cable failures and cable pull-out.
•Overmolding process ensures reliable connections in harsh environments.
•They decrease downtime and maintenance costs related to damaged hoods or latch pins.
•Available in flex or static/tray for total design flexibility.
Lastly, proper employee training can provide the greatest improvement in connector life.
CABLE PULL-OUT
Excessive mechanical loading and improper strain-relief selection are the primary causes of cable pull-out, allowing the cable to work itself out of the backside of the connector. This increases the likelihood of cable failure, pin push-out, and short circuits. Some contributing factors are:
•Low-cost plastic strain-relief compression nuts.
•Improperly sized cable glands.
•Mechanical loading perpendicular to the connector.
•Excessive cable bend radiuses.
•Cable jacket degradation.
Proper strain-relief design is the solution. Select cable glands based on the cable OD and installation environment to ensure a tight fit and to maximize holding force. Do not use plastic  compression nuts. These can loosen due to thermal expansion and contraction, vibration, or gland-nut failure. Plastic strain-relief nuts will degrade over time from exposure to heat, ozone, or UV light and should therefore be checked often. Metal strain-relief nuts can be tightened more securely than plastic and will not degrade over time.
Jacket materials on hot-runner cables can be degraded by chemicals, heat, ozone, and UV exposure. Make sure that you select the appropriate jacket material for your manufacturing environment. Two common jacket materials are PVC and TPE.
CABLE FAILURE
Cable failure is costly. Common causes are:
•Current overload – running 15A circuits through a 10A cable.
•Physical abuse—pinching, cutting, or smashing the cable in tooling or other equipment.
•Heat—internal or adjacent to the cable.
•Stress from repetitive movement.
•Improper strain relief and tight bend radius.
Proper wire sizing is the most effective way to minimize costs associated with short circuits or burnt-up cables. Do not use a connector rated for 10A for a 15A application. Cables intended for 15A should be 16 Awg or more depending on the cable length.
Flex-rated cable, such as the Alpha XM Series (Flex Control) or Alpha F Series (Continuous Flex) from Alpha Wire & Cable, Elizabeth, N.J. (alphawire.com), reduce failures caused by repeated flexing. Running individual wires through a flex-rated conduit also reduces failures. Flexible power cable solutions are fairly simple. Flexible thermocouple cable solutions are more challenging. Sourcing flex-rated thermocouple wire and cable can be difficult and costly. Typical thermocouple wire uses a solid conductor, which does not accommodate flexing and will fail. Thermocouple cable assemblies should use stranded thermocouple cable or single-pair stranded thermocouple wire in flex-rated conduit. The reduced failure rates will offset the added cost.
Plastics Recycling Latam STD
2025 Twin Screw Report
Injection molding machines
Packaging
PET Preform Hot Runner System Reduces Stack Height
Mold-Masters has cut the stack height of its PET-Series hot runner system from 300 mm to 260 mm, while maintaining a 3-plate design and the advantages therein.
Hasco Marks a Century in Mold Components, Mold Bases and Hot Runners with Cake and New Technologies
NPE2024: Cake, drinks and the unveiling of a new North American website providing online ordering in the U.S. and Canada for the first time are just some of the things happening at Hasco’s booth as it brings its year-long centennial celebration to Orlando.
Hot Runners
Fast-Response Hot Runner Controller
MCS hot runner control systems from PCS company are designed to optimize performance, communication and control.
New Hot Runner Temperature Control
Oerlikon HRSflow’s T-Flow HRS control has launched with three models that are configurable to multiples of six zones.
Airtech International Inc.
