Deflection Elbows Eliminate Streamers for Large Film Processor
New elbows eliminate troublesome streamers to increase productivity at leading blown film processor.
A leading blown film processor eliminated a problem with streamers in its resin conveying lines by revamping its process and adding a new type of deflection elbow.
Blown film processor All American Poly (AAP) produces approximately 123 million pounds a year of sheeting, liners, bags and shrink-wrap for food, building supply, industrial, agriculture, furniture and textile applications in three locations. At its largest plant in Piscataway, New Jersey, AAP runs 23 blown film lines and produces some 115 million pounds of product a year running 15 different types of PE. These PEs are formulated and compounded to meet AAP’s requirements for density, gauge, surface characteristics, color, food contact, shrinkage, printing, UV resistance, anti-fog, flame retardancy and other properties.
Under the leadership of Corporate Project Manager Ed Komoroski, AAP has increased the system’s capacity and reliability over the past decade, doubling the number of silos and adding multiple conveying lines. Before he joined the company, material was conveyed pneumatically from rail cars into the plant through flexible hose, and then through pneumatic piping and sweep elbows to holding bins and extruders.
Ed Komoroski doubled the number of silos and added multiple pneumatic conveying lines at All American Poly’s Piscataway plant. Source: Hammertek
The high-volume conveying, together with PE’s relatively low melt temperature of 248 to 266°F, created a problem with streamers (also known as angel hair and snake skins).
The heat generated when the PE collided with the sweep elbows melted the material inside the conveying lines, forming streamers that jammed downstream equipment. This led to production tie-ups and demurrage charges while rail cars waited to be unloaded.
Upping Transfer Capacity, Efficiency
At the heart of AAP’s vastly revised process is a series of plantwide pneumatic vacuum conveying systems with more than 108 bends and 128 separate lines. The lines transfer PE pellets from rail cars to eight exterior silos, then to interior holding bins, and ultimately to mixers on an upper level and extrusion lines below.
To avert PE degradation and production delays, Komoroski turned to HammerTek and the company’s 90-degree Smart Elbow deflection elbows. The elbows feature a bulb-like protrusion that extends beyond the 90-degree pathway, creating a ball of material suspended in air that rotates in the same direction as the airstream that powers it. This causes incoming pellets to be deflected around the bend without impacting and heating the elbow wall, thereby preventing elbow wear, material degradation, melting and plugging.
HammerTek’s Smart Elbow design prevents PE pellets from impacting/heating the elbow wall, melting and forming streamers.
The elbows’ short-radius design enabled installation between the rail car siding and the building, and from silos through an exterior wall into the plant at 90 degrees.
AAP has installed more than 100 of the deflection elbows. Komoroski explains that AAP no longer experiences the maintenance issues caused by streamers, thereby improving production, and notes that Smart Elbow units will be specified on all new vacuum lines added to meet increased demand.
Breaking the Barrier: An Emerging Force in 9-Layer Film Packaging
Hamilton Plastics taps into its 30-plus years of know-how in high-barrier films by bringing novel, custom-engineered, nine-layer structures resulting from the investment in two new lines.
Film Processor Automates Complex Resin Management, Blending & Distribution System
Polipak of Poland moves to BlendSave system to support sustainability and Industry 4.0 objectives.
