Dyna-Purge and 3Dom Develop 3D Purging Compound
The new Dyna-Purge 3D Clean purging compound is geared to a broad range of FDM 3D printers.
By partnering with 3Dom USA, Fargo, N.D., Schuman Plastics’ Dyna-Purge Div., Depew, Buffalo has introduced a new grade of a safe, non-abrasive, non-chemical, FDA compliant engineered thermoplastic purging compound specially formulated for FDM (Fusion Deposition Modeling) 3D printers.
Dyna-Purge 3D Clean, is reportedly ideal for a wide range of 3D printing applications including plastic prototyping, multi-color 3D prints, low-volume production and others that require multiple color and resin changes for a broad range of FDM systems. The new compound is designed to purge all resins used in 3D printing. It is reportedly easy-to-use before or after printing a part, for color changes, resin changes, especially composite materials such as glass-filled nylons, and for preventative machine maintenance. Its ease-of-use is delivered through an innovative cleaning formulation and wide processing temperature range—from 320˚F to 575˚F.
It comes in 8-in. long strands (1.75mm and/or 2.85mm diameter) and packaged in a clear cylinder.
Want to find or compare materials data for different resins, grades, or suppliers? Check out Plastics Technology’s Plaspec Global materials database.
Latest Data on Bottled Water Shows Continued Strong Growth
Bottled water’s volume surpassed soft drinks for the first time in 2016 and has done so every year since.
