Gloucester Engineering Teams Up With Kabra in India
Gloucester Engineering Co. in Gloucester, Mass., has formed a joint venture with Kolsite Group in Mumbai, India, to build blown film lines at Kabra Extrusiontechnik Ltd., a Kolsite company.
