Plastics a Carpenter Could Love
Jim Rock has tried to put sawdust into plastics off and on for 20 years, long before wood composites became fashionable.
Jim Rock has tried to put sawdust into plastics off and on for 20 years, long before wood composites became fashionable. After first working with Union Camp in the 1980s and Erwin Forest Products in the ’90s, Rock formed his own consulting firm in 2000. Called Southern Composite Technology, it has 14,000 sq ft of laboratories in Newport News, Va., for testing building-code compliance of all types of lumber—wood, plastic, and anything in between.
Wood/plastic composites still fascinated Rock, especially as he understood more of the shortcomings of some of the commercial products he tested. So he bought a used Cincinnati Milacron CM 80 HP conical twin-screw extruder and began experimenting with extruding polypropylene composite lumber of his own. The resulting boards, which will become commercial next month, are believed to have the highest levels of wood filler (a minimum of 60%) combined with the highest level of foaming (40% weight reduction) of any lumber product on the market.
His is one of the few composite lumber grades that can be worked, sanded, planed, and painted like real wood. It is even close to the weight of natural wood. Commercial boards will have a density of 0.75 g/cc, equivalent to natural ash. The unfoamed composite would have a density of 1.15 g/cc. Rock has produced densities down to 0.65 g/cc on a developmental basis but hesitates to commercialize them because that would require retooling and reformulating. “Every step down in density is harder to make,” he explains.
He struggled for three years to develop a production-worthy process to make the lumber. Eventually he bought a failed PVC fencing plant in Lowland, Tenn., which gave him the material-handling, drying, and downstream cooling equipment that he needed to get started. His first two production extruders, 114-mm and 140-mm parallel twin-screws from ExtrusionTek Milacron, will be delivered this fall.
Works like wood
Rock says the big distinction between Southern Composite’s boards and virtually all the rest is that a carpenter can cut and build with his lumber just like real wood, instead of having to orient the boards so that their aesthetic surface layer shows on the outside, like other plastic lumber. And unlike coextruded deck boards, he doesn’t have to cover up the unsightly cut ends where the cap layers show.
Southern Composite is not aiming for decking products. Instead it will make exterior trim, which is designed to accept paint and competes with wood, composition board, and PVC. Unlike PVC exterior trim, his boards can be painted in dark colors without fear of heat distortion in hot climates. His boards also pass PPG Industries’ proprietary paintability test.
Most foamed wood composites are based on polystyrene or PVC, which are amorphous and easier to foam because they hold bubbles better. Only a couple of other processors use crystalline PP—Correct Building Products in Biddeford, Me., and Mikron Industries in Kent, Wash. Both have been in production for about five years, but neither one makes a product with both the high foaming level and high wood content of Rock’s product.
He gives much of the credit for development of his patent-pending product to support from additive supplier Reedy International Corp. in Keyport, N.J. Reedy worked two and a half years with Rock to develop the foaming agent and lubricant package for such a high wood content. “I compare it to trying to blow bubble gum with a mouthful of oatmeal cookie,” Rock explains. “The wood filler doesn’t foam, and there’s not much plastic to hold the bubbles.”
For three years Rock has been Southern Composite’s only employee. But now he has two colleagues: a sales manager and a toolmaker. “That’s handy with a product that requires new tooling every time you make a density change,” Rock notes.
NPE2024 Materials: Spotlight on Sustainability with Performance
Across the show, sustainability ruled in new materials technology, from polyolefins and engineering resins to biobased materials.
Read MoreHonda Now Exploring UBQ’s Biobased Material Made from Unsorted Household Waste
UBQ is aiming to expand its reach for more sustainable automotive parts as well as non-automotive applications.
Read MoreAvantium and U.S.’s Origin Materials Aim to Accelerate Production of FDCA and PEF
The partnership aims to bring together both companies’ technology platforms to produce FDCA from sustainable wood residues on an industrial scale.
