TA Instruments' ElectroForce Group Moves to New Digs
TA Instruments sees growth potential for its new acquisition's product line.
The ElectroForce Systems Group of TA Instruments, New Castle, Del., has moved to a new, 30% larger facility in Eden Prairie, Minn. It is now located in the Golden Triangle areas, a multi-use location that includes product development, customer service/support and manufacturing.
According to president of TA Instruments Terry Kelly, the company is excited about the growth potential of ElectroForce products, which it acquired from Bose Corp., Framingham, Mass., last May. The ElectroForce group manufactures dynamic mechanical testing systems, which are used to characterize engineered materials, biomaterials, and medical devices. These testing units are based on unique motor designs that are said to be quiet, energy-efficient, scalable, and deliver high performance over a wide range of force and frequency.
Try This Alternate Method for Heating Your Torque Rheometer
Rheometers are generally not on all the time. And most users have found that the first test run in the instrument after heating up is not very reliable and is usually discarded. Try this method instead.
Robust Rotational Viscometer
Versatile viscometer line said to offer robust measurement, repeatability and reporting.
Using a Melt Flow Indexer to Test Your Pressure Transducer
The MFI tester enables collection of meaningful pressure data in transducers in a relatively short time, providing realistic measures of the response time of a pressure transducer. This information is critical in the interpretation of pressure data measured in an extrusion process.
