CM-26dG Spectrophotometer
Cold Pressed-In Threaded Inserts: An Economical Alternative
Sponsored Content
Cold pressed-in threaded inserts provide a sturdy and cost-effective alternative to heat staking or ultrasonic-installed threaded inserts. Discover the advantages and see it in action here.
Cold pressed-in inserts can be an economical alternative to thermal or ultrasonic-installed threaded inserts for plastics processors.
This application method is designed for post-mold installation where the inserts are “cold-pressed” into the plastic part.
Requiring only a simple press, they eliminate the need for any auxiliary equipment, but it’s important to consider your application’s requirements first…READ MORE.
NEW CM-17d Spectrophotometer
Injection molding machines
Custom Assembly Configurator - ManifoldBuilder.com
