2025 Twin Screw Report
Engraved Rolls
Make sure that the outer shell is made from a seamless tube.
When a heat transfer roll is being engraved or textured, make sure that the outer shell is made from a seamless tube, either by using a seamless pipe tube or a seamless forging for rolls that are larger than 24 in./diameter. If the outside shell of the roll is made from a rolled-and-welded plate or tube, the weld area will not etch or engrave at the same texture as the base metal of the shell. Typically the weld seam of a rolled and welded tube has a totally different metallurgy, and usually the welded area is much harder than the base metal on either side of the welded area.
____________________________________________________________________________________
Injection molding machines
PT Top Shops
Custom Assembly Configurator - ManifoldBuilder.com
