Set new standards
Feedthroat Leakage Check
Simple tips to solve this problem.
Is feedthroat leakage causing you problems? The best solution is to plug the exit of the water flow, and install a pressure and a globe valve on the inlet side before the air supply. Fill the housing with water, the put full plant air pressure against the water in the housing.
Close the valve and let it stand over night. Then in the morning check and see if the pressure has dropped off. As long as all of the fittings are tight, there should be no loss in pressure in the testing systems.
____________________________________________________________________________________
2025 Twin Screw Report
Plastics Recycling Latam STD
Plastics Size Reduction
PT Top Shops
Dust-Tight Bulk Bag Unloaders
