We ❤ Powders!
Plastics Technology’s Most Popular Articles of 2017
Sinks, weld lines, gels, flash—many of the most popular articles on Plastics Technology in 2017 help processors address pain points in their day-to-day operations.
Words like ‘how’, ‘why’, ‘what’, ‘best’ and ‘solve’ figure prominently in the most-popular articles on Plastics Technology in 2017. Many of these articles continue to have relevance for processors even after their initial publication.
No. 1
Plastics That Conduct Heat
Helping electronics, lighting, and car engines keep cool are some new roles for thermoplastics that are formulated to replace metal or ceramic.
No. 2
No. 3
Extrusion Troubleshooter
Extrusion is a "black-box" process. We can't see what goes on inside an extruder, so we depend on instruments. We need to be sure that all sensors are working and readouts are calibrated correctly.
No. 4
How to Reduce Sinks
No. 5
No. 6
What's Causing Your Gels?
Gels are a common quality problem in extrusion of clear film and tubing less than 0.005 in. thick.
No. 7
Solving Four Common Problems in PET Stretch-Blow Molding
Here’s a quick guide to resolving four nettlesome problems in processing PET bottles.
No. 8
Thermoplastic Polyesters: It's Time to Know Them Better
There’s more to TP polyesters than you think. You may know PET, PBT, and PETG—but what about PCT, PCTG, PCTA, and PTT?
No. 9
How to Stop Flash
No. 10
Injection molding machines
Resinworks
