Dust-Free High-Performance
Solving Splay
Moisture and shear are the two primary causes of splay on an injection molded part.
Moisture and shear are the two primary causes of splay on an injection molded part. Let’s first discuss moisture, as most of the time splay is due to the fact that the resin has not been dried properly.
Resin drying is a time/temperature element. Most drying specifications for various resins are at temperatures where the resin will not agglomerate, and held there for a given amount to time for which the moisture in the resin will be reduced to a processable level. Splay caused by moisture can typically be easily spotted because it will move around from part to part; it will never be in the same place.
Splay due to shear can come from two sources. One source can be from the shearing action caused by the screw. This is due to high screw speed, or from a mixing section that has too tight of clearance on a mixing section. It can be determined if the splay is due to screw shear by slowing the rpm of the screw. By reducing the screw speed, the shear rate in the screw will be reduced and therefore should eliminate the splay seen in the part.
The other type of shear splay is due to shear at the gate of the mold. This splay will typically always show on the part directly in front of the gate of the part. This is caused by the fact that the gate is improperly sized, and during the injection of the part, the shearing action on the resin occurs due to the high shear rate at the gate area. It can be determined if this is the cause of the shear by reducing the injection speed of the resin into the mold. If by reducing the injection speed and the splay disappears, then the mold needs to be reworked to have the gates modified by either fanning the gate or possible adding additional gates into the part.
______________________________________________________________________________________
Injection molding machines
2025 Twin Screw Report
Plastics Size Reduction
PT Top Shops
Blending & Dosing
NEW CM-17d Spectrophotometer
Plastics Recycling Latam STD
Custom Assembly Configurator - ManifoldBuilder.com
