WSB Gravimetric Blenders
Boltless Flat Die Opens Faster
Without changing the inner workings of the die, Extrusion Dies Inc., Chippewa Falls, Wis., has come up with a revolutionary way to assemble flat dies without bolts. The closing mechanism replaces conventional die bolts with rods actuated by hydraulic toggles to hold the die halves together.
The new die allows rapid opening of a flat die in less than a minute instead of hours to unbolt a die by hand. The rod-and-toggle mechanism uses a hydraulic piston to move a toggle that raises or lowers two rods. A larger hydraulic unit closes four rods at the center of the die. Hydraulic opening takes 30 sec after the flip of a switch. When the rods are in the closed position, hydraulics shut off, and the die halves are mechanically locked together. The die has run successfully for 6 hr at pressures of 3500 to 4000 psi without leaking, EDI says.
Boltless dies are expected to be particularly advantageous for processing easily degradable resins like PVC, fluoropolymers, polycarbonate, and other heat-sensitive resins that require frequent clean-outs that eat up a lot of production time. "Conversely, the sheer ease of this boltless system will cause processors to clean dies more frequently, ensuring higher levels of product quality," says John Ulcej, executive v.p. of engineering and technology, who led the project to develop the system.
The boltless system can be used on any of EDI's flat dies for film, sheet or coating, but it will cost a premium over conventional bolts. How much of a premium isn't certain because the technology is so new that EDI doesn't know what its manufacturing costs will be.
Masters of Blending
