Products
Star Plastics PFAS-Free Compounds
New polycarbonate compounds free from per and poly flouoralkyl substances.
Read MoreDual-Shaft Mixer for Robust Industrial Mixing
Units are engineered for wide-ranging densities and viscosities up to several hundred thousand centipoise.
Read MoreHole Filter for Demanding Melt Filtration Applications
Especially designed for use in machine nozzles and sprue bushings, Hasco’s H5055/… hole filter provides low pressure loss and high filtering performance.
Read MoreCustomizable Cobot Palletizing Tool
Piab USA says after two years as a specialty product, its cobot palletizing tool (CPT) end-of-arm-tool is now a standard configurable product.
Read MoreXenia 3DF Materials for FFF Printing
Xenia is introducing new filament materials for fused filament fabrication.
Read MoreAxiom AX Gratek PP40 Offers Increased Tensile Strength at Lower Weight
Graphene nanoplatelets enhance properties for engineering compound.
Read MoreBlown-Ion Plasma Treater 'Bombards' Surfaces
The treater is suited for applications requiring uniform surface treatment to improve adhesion at high speeds.
Read MoreExpanded Blade Ejector Line
Progressive Components has expanded its blade ejector line, which includes optional “Mold-Ready” features that reduce the need for in-house machining.
Read MoreHot Runner Design Prevents Overheating, Excessive Heat Loss
Germany’s Heitec says the new Primo line of nozzles are available in North America from Technoject Machinery.
Read MoreNeste RE Adds Co-Processed Feedstock
Feedstock for polymers and chemicals will be derived from renewable materials along with crude oil.
Read MoreThermal Insulating Sheet Targets Highly Stressed Molds
Hasco’s Z12120/… thermal insulating sheets prevent uncontrolled heat dissipation from injection and compression molds into the platens.
Read MoreSABIC Polycarbonate Copolymers Resistant to Chemical Exposure
Specialty materials for mobility, electronics, industrial and infrastructure markets.
