3D Printing Machine Training
Low-Scrap Thermoforming Competes In Medical Orthotics Manufacturing
An example of how thermoforming is expanding into more and more sophisticated and high-tech applications is the case of orthopedic devices to improve posture, function, and mobility.
An example of how thermoforming is expanding into more and more sophisticated and high-tech applications is the case of orthopedic devices to improve posture, function, and mobility. Restorative Care of America Inc. (RCAI) in St. Petersburg, Fla., relies on innovative use of thermoforming to produce orthotic devices. It claims to be unique in its use of this process, while competing products are based on metal or injection molded plastics.
RCAI has expanded its use of vacuum forming and a variant of the process called drape forming to produce splints, cuffs, stays, hinges, braces, and joints that comprise many of its roughly 70 orthotic products. RCAI is enjoying annual growth of up to 10%. Its most popular device is the foot orthosis, which comes in nine sizes.
Drape forming’s benefits
Orthotics traditionally have relied heavily on aluminum and stainless steel. But conventional orthotics exert pressure on sensitive body areas that can contribute to soreness, and they can be difficult or impossible to adapt to individual patients by a doctor. RCAI says its use of plastics overcomes both those limitations. Most of RCAI’s products use drape-formed Kydex high-impact acrylic/PVC sheet from Kleerdex Co. LLC, Bloomsburg, Pa. It offers flexibility, tensile strength, and toughness.
In the drape-forming process, a 4 × 4 ft sheet, 0.125 to 0.187 in. thick, is heated to around 295 F, well below the material’s melting point of 320 to 390 F. Semi-molten sheet is then machine-stamped into a template of various parts arranged to minimize scrap (typically only 3%). The templates are cut into individual parts with a CNC router, Those parts are reheated to around 295 F, and loaded into a cold mold half (typically made of a composite). The soft sheet conforms to the mold without any pressure or vacuum. Cycle time is around 2 min.
Compared with traditional thermoforming, drape forming is relatively simple, “low-tech,” and more labor intensive. It yields parts with minimal built-in stress, exceptionally low and predictable shrinkage, and highly uniform wall thickness.
According to RCAI, drape forming offers new design opportunities. The approach makes it feasible to eliminate pressure points and reduce the risk of contact soreness. Drape molding also permits the orthotic device to be reheated and reshaped in the field with a heat gun by medical practitioners. Orthotics can thus be repositioned at a new angle, or a range of motion can be modified as prescribed by a doctor’s treatment plan.
Heat-formability of drape-formed parts also means that orthotics supplied in basic prefabricated sizes can be custom-fitted to individual limb sizes or conditions (e.g., degree of swelling). For example, the diameter of a holding cuff can be modified for precise fit on an affected limb. RCAI says Kydex sheet allows parts to be adjusted many times without compromising tensile strength or other key properties.
RCAI has also extended its capabilities to include vacuum forming of orthotic parts that require high draw ratios, more variable wall thickness, or properties offered by alternative thermoplastics. For example, RCAI vacuum forms polyethylene into universal wrist/thumb splints and shoe inserts; and nylon is used for hinges, support plates, and ball-and-socket joints.
RCAI drape forms about 12,000 parts monthly and vacuum forms a similar number. It faces strong competition from China and Costa Rica. Cost pressures in recent years have forced many orthotics suppliers to make their parts offshore, but RCAI’s “made-in-the-U.S.” approach has succeeded despite its labor-intensive nature, says Bud Hess, RCAI president. He credits in part the low scrap and minimal reject rates for drape forming and vacuum forming, plus the ability of these technologies to meet just-in-time deliveries. Turnaround time for custom plastic parts is three to four weeks, versus 10 weeks for competitors who rely on foreign-made parts.
Process Cooling
industry 4.0
Equipment suppliers’ latest innovations exemplify this trend driven by factors such as labor shortages, higher-speed thermoformers and tighter quality control.
Origin Materials Unveils CapFormer for Producing PET Caps
Factory acceptance test completed at commercial scale.
Thermoforming
Thermoformer Maximizes Productivity with 3D Printing
Productive Plastics has created an extensive collection of 3D printed manufacturing aids that sharply reduce lead times.
Thermoforming
ExxonMobil Develops High-Performance, 95% PE Recyclable Thermoformed Packaging
The packaging solution involved a collaboration with equipment suppliers Hosokawa Alpine and Multivac Group.
3D printing machine trainings
