Modern Machine Shop ad
New Source of Crossheads
WEB EXCLUSIVE JoeTools, a supplier of plasticating components for extrusion and molding, is expanding its product line with ThermoGuard insulated crossheads for building and communication wire, medical tubing, hose, and pipe.
WEB EXCLUSIVE JoeTools, a supplier of plasticating components for extrusion and molding, is expanding its product line with ThermoGuard insulated crossheads for building and communication wire, medical tubing, hose, and pipe. The heads have a fiberglass-insulated exterior and PTFE sheathing to make it easier to maintain correct process temperatures and reduce energy cost. The heads are said to maintain a lower surface temperature, adding to shop safety and comfort. JoeTools offers fixed-center and adjustable crossheads, as well as special designs, such as a Universal style for use with all tips and dies, and a multi-conductor head with a conveniently exposed feed area that eliminates tedious, long-distance feeds and greatly reduces setup time. (877) 832-7864 * www.joe-tools.com
  • Single vs. Twin-Screw Extruders: Why Mixing is Different
    There have been many attempts to provide twin-screw-like mixing in singles, but except at very limited outputs none have been adequate. The odds of future success are long due to the inherent differences in the equipment types.
  • What to Know About Your Materials When Choosing a Feeder
  • How Polymer Melts in Single-Screw Extruders
