Now You Can Refurbish Twin-Screw Elements
Two suppliers of twin-screw compounding extruders announced at NPE2012 that they are now offering screw-element refurbishing services.
Two suppliers of twin-screw compounding extruders announced at NPE2012 that they are now offering screw-element refurbishing services. These are believed to be first-of-a-kind services in compounding.
Specifying an altogether new element was typically less expensive for compounders than getting one refurbished. But both ENTEK Extruders, Lebanon, Ore., (pictured) and Coperion Corp., Ramsey, N.J.,
have taken advantage of the economies of scale from their in-house screw manufacturing capabilities to make refurbishing a lower-cost alternative.
ENTEK is offering the service on extra-large elements (133 and 250 mm). Coperion is offering refurbishing service across a full range of sizes. It does screw manufacturing in Wytheville, Va., where it reportedly has the capacity to produce 120,000 to 140,000 elements a year.
How to Configure Your Twin-Screw Extruder for Mixing: Part 5
Understand the differences between distributive and dispersive mixing, and how you can promote one or the other in your screw design.
How to Configure Your Twin-Screw Barrel Layout
The Path to Pellet Perfection
In underwater pelletizing, numerous variables in the equipment, process and material affect pellet shape, consistency and quality factors such as fines. Defining the “perfect” pellet depends on the conditions of end use, and achieving that ideal requires understanding of the causes of imperfections.
