Stop Controlling Your Injection Molding Process with Machine-Only Settings
Monitor and record process outputs instead of the machine setpoints to ensure a validated process regardless of any machine deterioration, viscosity changes or other alterations.
You just established a stable process—now what? You probably record the machine setpoints on a setup sheet, right? You may even make the mistake of validating your process based on these setpoints. But these figures don’t always correlate directly with the actual output. Here’s an analogy for you: You have your cruise control set at 55 mph, but you are going down a steep slope and your speed goes up to 70 mph. A cop catches you and pulls you over—does he care that your cruise control was set to 55? Probably not. He only cares that you were going 70. In other words, the setpoint doesn’t matter, the output does.
Machines Wear, Setpoints Fade
The injection molding machine itself is a piece of machinery used to produce good-quality plastic parts in tolerance and within the quoted cycle time. The key word there is machinery. What happens to any piece of machinery, whether it is mechanical, hydraulic or servo-driven electric? They are all prone to wear over time, and if you do not have a robust preventive maintenance plan in place, they will more than likely wear even faster than they are intended to. Once these machines start to wear, do you know whether it is still hitting the setpoints you entered into the controller? Some machines have hundreds of setpoints, so let’s focus on a few that can have an impact on part quality.
Injection Speed Linearity Test
In RJG’s training courses, we teach about the Injection Speed Linearity test. This is one of the most important tests processors can run on their molding machines to see how accurate the actual machine’s injection velocity is compared with its injection-velocity setpoints. A few important factors can have an influence on whether your machine can actually hit these setpoints.
One key factor is the shot size. If it is less than 20% of the machine’s maximum shot size, there is a good chance it is not hitting the injection-velocity setpoint. Here’s another analogy: If you were offered any car of your choice for free but you had to hit 100 mph within 10 ft in order to receive it, would you be able to do it? Of course not. You wouldn’t have enough distance to obtain the necessary speed. That same rule applies to injection molding machines. If you do not have enough shot stroke, the machine does not have a chance of hitting the actual injection speed you’re trying to achieve.
FIG 1 Use an injection-speed linearity test to determine actual injection speed for a process.
(Images: RJG)
Figure 1 shows an example of an injection speed linearity test using only 6% of the machine’s maximum shot stroke. The machine was set at 5 in./sec, but it was only able to achieve 2.5 in./sec. That’s not because it was a bad machine, but because it was running a mold that was below 20% of the maximum shot size we recommend.
Throwing Darts
Surprisingly, we still find numerous molders that are recording injection, pack and hold pressures in hydraulic psi. These pressure setpoints do not always produce the same part from machine to machine. That is mostly due to differences in intensification ratio—of the area of the injection cylinder to the area of the screw—between different machines.
You also lose the ability to monitor viscosity shifts that you would see while monitoring the specific pressure during the filling phase of the process. To help people understand this better, I like to use the analogy of playing darts. If you are standing back at the throw line, how hard is it to hit a bullseye on every throw? For most of us, it can be pretty difficult. This is like measuring the hydraulic pressure on the back of the injection unit. These setpoints don’t guarantee that the machine is producing the same part from shot to shot, day to day, or year to year. However, if we place cavity-pressure sensors inside the mold and look at post-gate pressure and end-of-fill pressure, that is like standing directly in front of the dart board.
Hit a Bullseye on Every Cycle
As long as the sensors are placed in the proper location, a molder has data that can catch short shots, dimensional variation, pack rate, cooling rate and gate seal (to name just a few parameters). These are all considered outputs that can be monitored and can have alarm limits set around them to ensure you hit a bullseye on every cycle. This also makes it easier to match your process from one machine to another. Two machines may not perform exactly the same way, even if they are the of same brand and have the exact same specs. That means if you try to match a process based on setpoints, you may end up with two completely different parts. However, if you were to match critical aspects of the data from cavity-pressure sensors, you have a better shot at making the same part regardless of machine wear, viscosity shifts from the material, or which machine it runs in.
Here’s another example: When you look only at the machine temperatures, they are very rarely running exactly at the setpoints. Just to keep it simple, if you were to set all zones for the barrel temperatures at 460° F, how many of these zones would be exactly at 460° F? If you were to look at the controller at any given time, you might find one or two zones at this temperature, but sooner or later, they are going to go higher or lower than the setpoint. How high or low depends on the machine’s temperature controller, PID loops, thermocouple placement and the heaters themselves.
If you move this same mold and process to another machine, all of these variables may be different. Even if you use the same temperature setpoint of 460° F, you may see completely different temperature readings on the controller. If you account for the different barrel sizes, residence times and screw designs between the two machines, you will find the actual melt temperature may be drastically different, even with the same process setpoints. Figure 2 shows the difference between barrel temperature setpoints and actual barrel temperatures on a machine controller.
FIG 2 Just because you’ve set a barrel to a specific temperature doesn’t mean it’s actually at that temperature.
When we performed a melt-temperature test using a thin wire probe and a pyrometer, we found that the actual melt temperature was 463° F (see Fig. 3). Although in this case the melt temperature was very close to the machine setpoint, it is not always the case.
FIG 3 Use a device like a pyrometer to determine actual temperature of the resin.
A great example of this was during a customer visit a couple of years ago. I was helping them investigate scrap issues between two different machines that were purchased at the same time from the same manufacturer and built to the same specs. They were running two identical molds with the same material and the same process setpoints. They couldn’t understand why one of the machines was running around 3% scrap but the other machine was running more than 10% scrap. To their surprise, there was a 40° F difference in actual melt temperature between the two machines. Once they went away from matching the temperature setpoints and matched the actual melt temperature between the two machines, they were able to run similar scrap rates.
Different Controllers, Different Setpoints
Some machine controllers will read certain process setpoints in percentages. If you only record the percentage setpoint, it can get you in trouble in the future if you do not record the actual as well. There is nothing wrong with a machine that reads in percentages, however while running these machines there are two important variables that must be considered: the maximum for this setpoint and the actual output.
Figure 4 shows a machine controller that reads the injection flow rate in percentage. If you don’t know what the machine’s maximum injection flow rate is, then how will you ever know what 60% is? If you have one machine that is capable of 10 in./sec and another that is capable of only 8 in./sec, this 60% can be a huge difference in injection flow rate.
FIG 4 If your machine control gives you injection flow rate in percentages, you need determine what the maximum injection flow is to give those numbers meaning.
It doesn’t mean that either machine is not capable of producing good parts, it just means that 60% is not the same setpoint between both machines. In a case like this, it would be important to record the volume of material you are injecting and the actual fill time of the process. If you inject the same volume of material in the same amount of time, then you are matching the volumetric flow rate for this process, which makes it much easier to replicate the validated process every time it runs.
Molders often need to revalidate processes because the setpoints they have validated no longer produce parts with the same quality. In today’s market, molders have to be as cost-effective as possible to be competitive, and if you are continuously revalidating your process it eats away at your profits. At the end of the day, you are going to be more successful if you monitor and record process outputs instead of machine setpoints. This gives you the ability to match the validated process regardless of any machine wear, viscosity shifts or machine changes.
Editor’s Note: The author passed away shortly after contributing this article and it is published as a tribute to his industry contributions.
ABOUT THE AUTHOR: Jim Clifford was a consultant/trainer at RJG. He had almost 30 yr of experience in the injection molding industry and was an RJG Qualified Trainer since 2012. His core competencies were process development, troubleshooting, leadership, and continuous process improvement practices. Before his passing he had experience with launching new tools, troubleshooting existing tools, and performing safe and efficient quick mold changes.
The Cosmetic Process Window: Key to a No-Tweak, Robust Process
Establishing a process with the widest possible cosmetic window can help put your injection molding on cruise control.
Read MoreINJECTION MOLDING: Develop Guidelines—Not Strict Procedures— For a Robust Molding Process
‘Fool-proof’ dos and don’ts will prove foolhardy in a process with so many variables. You aren’t slinging burgers.
Read MoreHow to Quickly Verify Your Machine & Process Setpoints
For a quick check of your process setup, the injection-pressure-vs.-time graph is your best tool.
