Victrex Acquires Kleiss Gears to Bolster PEEK Gears Growth
PEEK resin producer buys specialist in injection molding gears.
Victrex, West Coshohocken, Pa., has acquired polymer gears specialist Kleiss Gears, Grantsburg, Wis. Kleiss designs, prototypes, and injection molds standard-size and micro gears, with particular expertise in molding PEEK. In moving downstream in this manner, Victrex is aiming to accelerate the adoption of its Victrex PEEK in gear applications to meet the needs of the automotive industry.
The strategic decision to acquire Kleiss Gears is consistent with the goal to provide improved service, specifically on PEEK-based gears, bringing much-needed capability for engineering design, tooling, and durability testing. According to David Hummel, Victrex CEO, “The market for PEEK gears is still much in its infancy, and in order to facilitate market growth, Victrex has identified that an integrated capability is needed to provide the right robust gear solution in order to meet the high demands of Tier 1 and OEM customers.”
Atop the Plastics Pyramid
PEEK for Monolayer E-Motor Magnet Wire Insulation
Solvay’s KetaSpire KT-857 PEEK extrusion compound eliminates adhesion and sustainability constraints of conventional PEEK or enamel insulation processes.
Design Optimization Software Finds Weight-Saving Solutions Outside the Traditional Realm
Resin supplier Celanese turned to startup Rafinex and its Möbius software to optimize the design for an engine bracket, ultimately reducing weight by 25% while maintaining mechanical performance and function.
