Melt Delivery Systems: Going Against Tradition
When it comes to part design, the importance of a properly designed melt delivery system is often neglected.
Stephen Levy, ADTS Engineer, PolyOne Corp.
A well designed part is only as good as the melt delivery system feeding it. The goal of a properly designed melt delivery system is to create uniform melt conditions to each gate while accommodating filling pressure limitations, minimizing shear, and providing for cavity packing.
Traditionally, melt delivery systems are sized based on estimates, similar part geometry, or poor design guidelines. However, when sizing a runner, it is important to minimize any restrictions of the material flowing through the channel. The cross-sectional area (diameter) of the melt delivery system has the biggest impact on both pressure drop and shear rate through the channel.  At a constant flow rate, both pressure and shear rate will increase with decreasing runner diameter to a point.
The pressure on plastic melt can be quite high during both mold filling and packing phases. During mold filling, the pressures can exceed 20,000 psi, with a maximum pressure at the injection nozzle and zero pressure at the flow front. Under high pressures, plastics are compressible, and that compression increases the interaction of the polymer chains, resulting in an increase in the resistance to flow or increase in viscosity. This phenomenon usually occurs at the gate when the formerly free flowing material suddenly hits a restrictive geometry. As a result, back pressure develops which in turn spikes the velocity of the material through the gates causing excessive shear rates.
During the injection molding process, excessive shear rates can typically lead to both shear-induced stress and degradation. Shear-induced stress results from the resistance to flow as the polymer chains drag, or stretch, against the cavity wall in the direction of flow. As a result, these residual stresses can contribute to distortion or premature part failure. If the shear rate becomes too excessive, the polymer chains can degrade as a result of being physically torn apart,which can affect both physical and cosmetic properties of the molded part.
To avoid excessive pressure limitations and shear rates, modifications to the melt delivery system need to be made to avoid restrictions in the melt stream. Starting at the sprue, it is recommended that its rear opening should be 1.5 mm larger than the nominal wall thickness of the part being molded. However, depending on the flow length and part volume, this opening may need to be widened further (2-3 times the nominal wall) to compensate for the added volume.
Sizing the Primary Runner
As a rule of thumb, the diameter of the primary runner, or enclosed diameter in a trapezoidal runner, should match the diameter of the rear opening of the sprue to maintain a constant volumetric rate of filling. The cross-sectional area of the following runner branches (secondary, tertiary, etc.) should be stepped down roughly 15% respectively to maintain an unrestrictive volume of material at a constant flow rate. Fishbone and non-geometrically balanced runner layouts should be avoided because they cannot provide uniform conditions to the multiple gates they are feeding. In a multi-cavity runner layout or a single cavity tool with multiple gates, in most cases, the flow length between the sprue and each gate should be identical to provide the most uniform melt conditions through each gate, depending on the part geometry.
The gate is the critical connection between the runner system and the part geometry that can significantly affect the ability to successfully mold a part. Too small of a gate causes a disturbance in the melt, which restricts the natural flow of the material. As previously stated, this can cause excessive shearing of the material or other gate-related defects. To avoid such issues, against standard traditions and practices, gates should be sized 75-100% of the wall thickness of the part to which it is attached. By doing so, the restriction of the free flowing material through the runner channel will be minimized. In addition to the size of the gate, the transition between the feeding branch and the gate must be properly tapered and given generous radii. Sudden sharp edges act like a knife-edge which can shear the material as well.
Should You Add Cold Slug Wells?
Another factor to consider while designing an optimum runner system is to add cold slug wells.
Cold slug wells are used in cold runner systems to capture cold slugs. Cold slugs are solid, or partially solid, pieces of plastic that form in the nozzle tip as a result of its contact with the cold mold. During injection, the cold slug is injected into the sprue and travels through the melt stream. If the cold slug is not captured, it may disrupt the flow by partially or completely blocking the melt stream. By extending the runner branch feeding into an intersection, this provides a place for the cold slug to be captured before it reaches the part cavity. It is common practice to have a cold slug well at the base of the sprue and at each intersection in the runner system. The cold slug well should maintain the same diameter as the runner branch feeding into the intersection and extend 1.5 – 2.0 times the diameter past the intersection.
Larger Gates, Less Shear, Few Cosmetic Defects
The melt delivery system is the critical channel connecting the molding machine with the part geometry. As against common practice, the benefits of a larger gate minimize the effect of shear induced stresses and cosmetic defects associated with undersized gates and as a result, a wide, robust processing window is achieved.
As an added note, as with all designed melt delivery systems, a mold simulation analysis should be completed to ensure the design is within recommended processing limits. While setting up the analysis, beam elements should be used to simulate the runner system while triangular elements (Dual-Domain) or tetrahedral elements (3D) can be used to finely mesh the gates. Simply using injection cones attached to the part geometry is not an accurate representation of the injection molding process and will result in misleading outcomes. Figure 1 (below) represents a melt delivery system (part geometry hidden) composed of beam elements and triangular elements modeled in to accurately perform a mold filling simulation utilizing Autodesk Moldflow.
injection molding runner system
About the author
Stephen Levy graduated from Penn State Behrend in December, 2015 with a degree in Plastics Engineering Technology. He currently works as an ADTS Engineer at PolyOne in Avon Lake, OH where he provides CAD design and Moldflow simulation support. Stephen is also a content contributor for Elite Machinery Systems.
NEW CM-17d Spectrophotometer
Injection molding machines
Blending & Dosing
2025 Twin Screw Report
PT Top Shops
Plastics Recycling Latam STD
Process Cooling
How to Achieve Simulation Success, Part 1: Model Accuracy and Mesh Decisions
Molding simulation software is a powerful tool, but what you get out of it depends very much on your initial inputs. Follow these tips to create the most successful simulation possible.
Automation
PT Top Shops
