Drying
Dryers are used to minimize or eliminate problems that moisture in the plastics cause during processing. Includes resin drying; hygroscopic resins; desiccant dryer; wheel dryer; vacuum dryer; drying PET; drying PC; drying ABS; drying nylon.
ACS Names New Regional Sales Manager
Feeding & Blending
Matt Trump to handle Ohio Valley for auxiliary equipment supplier.
READ MORE
ESSENTIAL READING
VIEW ALL
processing tips
PET
Follow These Seven Management Tips for More Consistent Resin Drying
Equipment and advice sure help, but ultimately, good management makes the difference.
Drying
Spring Tips for Dryer Maintenance
The warm, humid weather really puts a strain on both the regeneration and process, so it is important that everything is in perfect working order. The time to check is now.
What You Need to Know About Drying Specialty Nylons
PPA is being used more frequently by molders for demanding high-heat applications in automotive and other markets. While in the nylon family, it does not dry quite like nylon. Follow these tips.
processing tips
Water Droplets in the Feed Throat
And other reasons you must dry hygroscopic resins.
Latest Drying News And Updates
PiovanGroup Announces Transition In Leadership In North America
John Erkert ascends to Regional CEO position for North America as industry veteran Kirk Winstead retires.
Drying
Streamlined Drying Process Speeds Up Changeovers
NPE2024: Maguire demonstrating increase in productivity possible by vacuum drying.
Drying
Program Provides Equipment Maintenance, Overhauls and Upgrades
NPE2024: Program aims to ensure equipment remains at peak performance levels throughout its life cycle.
Drying
‘Smart,’ Moisture-Based Drying Technology Enhanced
NPE2024: Novatec relaunches DryerGenie with a goal to putting an end to drying based on time.
Drying
Dryer, Blender for 'Real Time' Regrind Usage
NPE2024: Dri-Air Industries and  Maguire Products join forces on the former’s second generation of on-demand drying/blending systems for the circular economy.
AI Manages Resin Drying Airflows and Throughputs for Energy Savings
NPE2024: Optional feature automates the process of maintaining process-ready resins at perfect temperatures and varied throughputs, while preventing overdrying and realizing significant energy savings.
Featured Posts
Blending Specialists ABS Relaunching Thoreson McCosh Dryer Line
NPE2024: Advanced Blending is taking the wraps off reinvigorated Thoreson McCosh drying line.
Novatec Putting the ‘Smart’ In Resin Drying, Conveying
NPE2024: Machine builder gets ‘ludicrous’ by rewriting the rules for material drying and conveying.
Connectivity for Material Handling Offers Greater Visibility
NPE2024: Motan solutions integrate data connectivity.
Watch
Drying
FAQ: Drying
How to dry resins?
Proper drying requires attention to detail in the following areas: temperature and moisture content (dew point) of the inlet air, volumetric flow rate of the air across the pellets, time the material is in the drying hopper, and temperature of the return air coming back from the hopper to the drying unit. There are other areas of concern related to the design and maintenance of the system. This also assumes that a desiccant dryer is being used.
How can I achieve more consistent resin drying?
  1. Control Initial Moisture Levels in Undried Resin
  1. Size Dryers Properly
  1. Dry at Correct Temperature
  1. Keep Drying Hoppers Full
  1. Limit Machine-Side Material Inventory
  1. Keep Airflow Clean and Consistent
  1. Invest in a Moisture Analyzer
